Old 03-26-2009, 06:00 PM   #1
LosiLST's Avatar
Default Newbie to electric
So I have decided that I am finally going to make the move to electric for the time being. I am going to buy a 3905 Emaxx and use it for just general bashing.
I need help deciding on What batteries and charger to buy. I like these ones:
Hyperion EOS 0606i
With
two SMC 2S1P Hard Case Li-Poly
Are those Lipo's good? Is the Charger any good? Will the charger charge both packs at once? Anything I should know, anything else you recommend?
Any other suggestions?
Team Losi LST2
LosiLST is offline   Reply With Quote
Old 03-26-2009, 06:09 PM   #2
porkey's Avatar
Thats a good start. Im not sure about the emaxx ESC but the novak lipo cut-off doesnt work. I now it doesnt work for the slash but im not sure about the emaxx.
AE T4: 8.5 AE B4: 10.5 AE B44: 7.5
www.michianabuildingsupplies.com(Sponsor)
www.embassyrcraceway.com
www.michianarc.com
www.steelmx.com(Sponsor)
porkey is offline   Reply With Quote
Old 03-26-2009, 06:10 PM   #3
snowboard094's Avatar
Hyperion EOS 0606i
With
Those batteries are great. I have used my SMCs for a long time.
-Electrical wiz-Let me check your shorts.....that came out wrong
"Team Terrible"
Ofna Hyper 10sc
T-maxx O.S .18tm
snowboard094 is offline   Reply With Quote
Old 03-26-2009, 06:42 PM   #4
Kings Kid's Avatar
Trader Rating: 35 (100%+)
I've been using the Hyperion duo and smc batteries for awhile Both are verygood choices.
Kings Kid is offline   Reply With Quote
Old 03-26-2009, 06:54 PM   #5
I just bought 2 SMC 28C 5000mAh with the novak Cut-off for my 3905, I haven't had a chance to use them because I'm waiting for my balancer....What problem did you have with the Novak cut-off....everything I read said it was the best option for going Lipo with the EVX2.
maybelater30 is offline   Reply With Quote
Old 03-26-2009, 07:41 PM   #6
Trader Rating: 21 (100%+)
The smart stop doesn't work on the stock Slash esc - it works on orig EVX in the 3906 or the EVX2 in the 3905 just fine.
The smart stop is wired to the battery that runs BEC, rx and servos - this batt is used more and will go low voltage 1st. Protect that batt and the other is automatically protected. There is no place on the outside of the ESC where you can get 16.8v (or 14.4v) and use a 4S smart stop, reason you use a 2S - unless you want to dig into the EVX.
If you plug one batt into the EVX and then turn switch on - if esc light comes on, thats the side that runs the bec, rx and servo - this is the side to wire the smart stop to. Note motor will not run this way. If esc light doesn't come on, thats not the side you want.
Smart stop is the best option to use on a 3905.....I'm doing it to my 3906, just haven't finished since weather here is rain.....
Duster_360 is offline   Reply With Quote
Old 03-26-2009, 11:51 PM   #7
$Tmoney$'s Avatar
Trader Rating: 28 (97%+)
i love my hyperion and wouldnt buy anything else
$Tmoney$ is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
Cebu RC Fly Boyz jpn Manila Racers 4045 09-16-2016 02:29 AM
Losi 8ight New Conversion questions! NEWBIE! hemi4me Electric Off-Road 6 03-08-2009 02:35 PM
newbie here need help from every one opinion dcwk24 Malaysian R/C Racers 60 02-12-2009 06:56 PM
Newbie in 1/8 electric need some suggustion for setup and motor. m3cosmos Electric Off-Road 12 12-06-2008 09:50 PM
5 Cells, the time is now!! Or atleast by 2008 Frank Root Electric Off-Road 421 08-20-2007 05:52 PM
