Old 03-25-2009, 11:58 AM   #1
oldandnew's Avatar
Questions?? T4 shorts?
This is probably a very stupid question but I would rather ask then find out the hard way. I think I remember reading this tell me it is wrong please. Is there a posiability of a short between the terminals on a matched set of NiM. Batt. and the graphite chassi of the T4 team kit. I think I remember reading this a while ago and I am about to try our first matched set of Nim. Batt. The stick packs had shrink over the ends so that the terminals are not exsposed. Thanks
oldandnew is offline   Reply With Quote
Old 03-25-2009, 04:04 PM   #2
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
With the graphite chassis, yes there is a chance of a matched NiMh pack shorting out. You can use some electrical tape to insulate the chassis from te pack, or for something more durable try this.
http://order.aeteam.net/product_deta...?Itemcode=9787
It's a clear self adhesive Teflon sheet. It can be cut to any shape, as seen in the photo installed on a B44. It's what I've used with great results. Just be sure to build your packs nice and tight, so they fit in the battery tray.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 03-25-2009, 05:15 PM   #3
dougyunker's Avatar
The problem that is more common than the chassis is the graphite battery strap that is included with the factory team kit. If the terminals of the battery touch this, then a short will occur.
dougyunker is offline   Reply With Quote
Old 03-26-2009, 06:36 AM   #4
oldandnew's Avatar
Default how to correct?
Sprade is that sheet like a decal sheet could you use it to cover the inside of the batteries tray on the T4, and the graphite batt. Strap that is included with the kit is conductive? Wow this doesnít seem to be good engineering. What do the factory drivers do? (Besides run lipo) I guess my question is what did they do? LOL thanks
Old 03-26-2009, 10:49 AM   #5
oldandnew's Avatar
Default ????
Iím not sure I understand, it looks like this sheet is for the bottom of the buggy. Is the problem with the truck that the + - terminals short to the sides of the batt. Tray in the T4 truck? Or somehow to the things the chassis comes in contact with? In the buggy it looks as if the batt. sit a lot lower down in the chassis. When I say graph. I mean the composite material that comes with the T4 team kit. not the woven fiber stuff. that is what the batt. strap is made of. Sorry for jumping around thanks for any input.
Old 03-26-2009, 11:05 AM   #6
OTE_TheMissile's Avatar
Send a message via MSN to OTE_TheMissile
I've heard that before myself, but I never had a problem with my graphite chassis shorting out my side-by-sides. The carbon fiber battery strap did give me a little zap once, but the easy solution for that is don't bend your end terminals so they sit RIGHT NEXT to the strap.
Faster Than Factory
On The EDGE Racing, est. 2001 - Home of the 524, the Silverado Slammer E-MAX6X6, and the Sand Dollar prerunner
Mike Budzien | facebook.com/OTE.TheMissile | RIVCO Products | The RC Corral | iRacing.com
OTE_TheMissile is offline   Reply With Quote
Old 03-27-2009, 09:21 AM   #7
oldandnew's Avatar
I am getting mixed feelings about this. I can't believe that AE would make it this way if it is a problem. But this being said everyone tells me that the graphite is conductive? This seems crazy to me I guess I will just put electrical tape inside of the batt. compartment for now as a precaution. I can't imagine this is needed. People at the local hobby shop say yes it is conductive but don't worry about it if their is a problem address it then. This seems odd. Probably looking too hard at this to much time on my hands right now. But if it is conductive even a little it must be at least partly shorting out the cells when they are in the car? Oh well any input would be appreciated. Thanks
Old 03-27-2009, 10:15 AM   #8
aeRayls's Avatar
It will NOT be a problem period!!! I ran the "graphite" = "carbon fiber composite" chassis for a couple of years, not to mention I ran them for a LONG time on the B3 and T3. Some say it may have given them "glitches", but most likely NOT! The chassis wil not short out a battery. It really is a non issue dont worry about it.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 03-27-2009, 10:19 AM   #9
aeRayls's Avatar
Oh yeah, the "graphite" chassis' do not come in any of the kits anymore anyway, unless you have an older one or bought the chassis seperate.
Old 03-27-2009, 05:29 PM   #10
Yes it is like a decal sheet about 8X14 inches. I just cut it into strips to fit inside the battery tray on the T4. My T4 and B4 both have the molded carbon chassis, so I figured better safe than sorry. Proper placement of the + and - battery tabs will keep them from shorting out on the strap. Heck I used to run the Trinity aluminum heat sink battery strap and never got so much as a spark.
Three words...
Old 03-27-2009, 05:49 PM   #11
trx450racer174's Avatar
I have never had a problem with my B4 but i did line the tray with some thin
sticky backed felt just to be safe.
E.K.D. RC Paint Work
Team Serpent USA, Desoto Racing , Team DE Racing, Team Hitec, Team Trakpower, Futaba, Team AKA, TrackstarRC.
trx450racer174 is offline   Reply With Quote
Old 03-28-2009, 08:10 AM   #12
oldandnew's Avatar
Thanks for the info guys. Good Racing
RC10B4/T4 Forum DerekL Electric Off-Road 14339 12-13-2017 11:20 PM
BANZAI Motors Eddie Garrison Team and Company Discussions 11666 09-09-2015 01:43 PM
SC10 Thread JDCrow Electric Off-Road 12123 05-29-2012 05:40 PM
Family Hobbies On & Off Road Racing In San Diego Jon Kerr Racing Forum 10726 09-11-2009 11:29 AM
1/10th 4wd buggy which one? vwjuice Electric Off-Road 83 08-26-2009 12:24 AM
getting a t4. need help. eldivad1 Electric Off-Road 55 09-22-2008 01:28 PM
