Old 03-25-2009, 10:28 AM   #1
CaptainHowdyt13's Avatar
Trader Rating: 33 (97%+)
Default How do you know when it's time to rebuild the diff in your B4/T4?
Just curious....mine just doesnt seem "smooth". Sounds noisy, and I'm sure this aint how it's supposed to be out the box. The car has some miles on it for sure.
Thank you to the following companies for their support in 2017:
* Futaba * O.S. Engines * RC Racing Communications *
CaptainHowdyt13 is offline   Reply With Quote
Old 03-25-2009, 11:22 AM   #2
OTE_TheMissile's Avatar
Send a message via MSN to OTE_TheMissile
I'm thinking now would be a good time for you. Yeah, whenever it starts to get a really notched or crunchy feel to it, it's time for an overhaul.
Half the time all you need to replace is the two sets of balls (the ten or however many it is going around the edge of the diff gear and the 6 thrust bearings under the screw in the right outdrive), because you can flip the rings over and just use the other side.
Faster Than Factory
On The EDGE Racing, est. 2001 - Home of the 524, the Silverado Slammer E-MAX6X6, and the Sand Dollar prerunner
Mike Budzien | facebook.com/OTE.TheMissile | RIVCO Products | The RC Corral | iRacing.com
OTE_TheMissile is offline   Reply With Quote
Old 03-25-2009, 11:49 AM   #3
CClay1282's Avatar
Send a message via AIM to CClay1282 Send a message via Yahoo to CClay1282
Or you can take 360-400 grit sand paper and sand the diff rings smooth again. Put one ring at a time on the flat outdrive and put it down on the sand paper. Hold the outdrive and move in a circular motion till the visible "groove" is gone.
It will have cross hatches in the ring from the sand paper, but that is good. Gives the balls something to "bite" against.
Either way, definately a good time for a rebuild!
Chris Clayton
Team Hydra-Sharp / Leading Edge / Yardarm Marine Products
RC10T4 - FT / RC10B4 - FT / RC8 -FT - Soon to be tekno converted
CClay1282 is offline   Reply With Quote
Old 03-25-2009, 12:04 PM   #4
Gliptal's Avatar
I never replace my trust bearing
Gliptal is offline   Reply With Quote
Old 03-25-2009, 12:06 PM   #5
badassrevo's Avatar
Please check out the BFast Diff thread, you will not find a better diff.
http://www.rctech.net/forum/electric...ssociated.html
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 03-25-2009, 12:13 PM   #6
Tech Legend
Wild Cherry's Avatar
Should not have too unless it has been torque down to hard...
Wild Cherry is offline   Reply With Quote
Old 03-25-2009, 12:38 PM   #7
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
Man that is just silly, half of your diffs smoothness is in the thrust assembly.You should at least clean and re-grease it when you service the diff.
*Vandal 4wd Late model*XXX-T sprinter*Micro scale specialties 1/24 'rock monster' crawler*MSS Micro-Rail*MSS Micro-Funny*MSS Micro-Outlaw*
2wdMod is offline   Reply With Quote
Old 03-25-2009, 12:54 PM   #8
B-FAST R/C's Avatar
+1
Many consider it to be the weak link in the diff assembly
www.bfastrc.com *** Feel The Diff!! ***
arcshobbies mcculloughsrcracing
B-FAST R/C is offline   Reply With Quote
Old 03-25-2009, 01:02 PM   #9
Tech Legend
I never have to do anything to my thrust when I rebuild , just new rings and diff balls, thats all I`m usually replacing ...
