Old 03-25-2009, 08:10 AM   #1
SuperEk4's Avatar
Trader Rating: 32 (100%+)
Default How does a super 43T torsen help in a ep CRT?
Hi, i race in a converted ep crt, but not aggresive enough.Can this help?
http://www.rcplanet.com/Ofna_Torsen_...p/ofn10596.htm
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
Old 03-25-2009, 10:06 AM   #2
SuperEk4's Avatar
heard it can help in steering n stable in long straight. Anybody?
Old 03-25-2009, 10:17 AM   #3
Have you already tried everything else to gain steering?
-lighter diff oil in the front diff
-front shock oil &/or piston change
-shock springs in front
-shock mounting position
-toe out
How's your rear sidebite? If good, you could loosen up that a bit...
-stiffer rear end
Are you already using the popular tires for the track?
Seems like an expensive alternative if you haven't exhausted all the possibilities.
groundhogg is offline   Reply With Quote
Old 03-25-2009, 10:40 AM   #4
SuperEk4's Avatar
-toe out
-stiffer rear end
i am using hard springs in front & my shock mounting is the standard setup for Jamming CRT
Will med springs help?
I m using Hong Nor LRP tires
wats rear end bite?
Old 03-26-2009, 04:59 PM   #5
Based on your response, there are quite a few things you can try before investing $110 on a Torsen diff.
There is a nice website explaining RC vehicle handling.
http://users.telenet.be/elvo/
In the Suspension section, pages 1 & 8 should provide you some good info. But all is good reading if your willing to learn.
Based on your statement of 'not aggressive enough', I'm thinking you mean you don't have enough steering (doesn't turn tightly in corners)
Here's a couple of clips out of it.
Suspension section; page1
In general, you could say that stiffer springs yield less grip on that end of the car, and conversely, softer springs yield more grip.
less grip = less traction = less steering
Suspension section; page 8
For instance: if the front shocks are close to vertical, and the rears are somewhat laid down, the car will have a lot of turn-in steering; it will be very responsive. If the rears are close to vertical ,and the fronts are more laid down, t he car won't have a lot of turn-in, but it will have more steering in the middle of the turn; it will 'square'. In some cases, the rear might actually begin to slide. It works much in the same way as having stiff springs or heavy damping: if you have stiff springs, or heavy damping up front, the initial reaction when you enter a turn will be very strong. In the middle part of the corner the car will probably understeer, but it's the initial reaction that gives the car a 'responsive' character.
Doesn't answer you diff question, but trying to help.......
Old 03-26-2009, 07:48 PM   #6
SuperEk4's Avatar
Thx man, so where shld I start from first the position of my shocks or springs or even damper oil?thx man
