Old 03-24-2009, 02:37 PM   #1
LosiLST's Avatar
Default Going Electric, need help
Okay, so I have finally decided that i'm going electric, staying away from nitro.
I'm going to get the 3905 maxx.
My question is, what charger should I get?
I like the Duratrax ICE with the Hobbico Power supply, any other suggestions?
Also, What Lipos do you guys recommend?
Everything I'm going to buy, I'm going to go full bore into it, I don't want to buy NiMh packs and a cheaper charger just to have to buy again later on down the road. So what are your suggestions?
Team Losi LST2
LosiLST is offline   Reply With Quote
Old 03-24-2009, 02:38 PM   #2
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
Hyperion charger and SMC lipo batteries. I can say from experience it IS a winning combination.
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 03-24-2009, 02:40 PM   #3
LosiLST's Avatar
Does that charger need a power suppy? Or is it really only 100 bucks?
Team Losi LST2
Old 03-24-2009, 02:45 PM   #4
The 606 is AC/DC, the 610i, 720k, and 6109 DUO II will require an external DC power source.
Old 03-24-2009, 03:05 PM   #5
http://www.amainhobbies.com/product_...ducts_id/30548
Maybe that would work, 24C, 4100 mah, 2S, SMC, and still only $65.
LRP Z.28R - 3
Spur Gear - 0
howtowakeakar is offline   Reply With Quote
Old 03-24-2009, 03:05 PM   #6
LosiLST's Avatar
Okay, so this charger with two of these batteries look good?
Also, will that charger charge both batteries at once? And what does all the numbers on the Lipos mean? Like where it says 24C and such?
Team Losi LST2
Old 03-24-2009, 03:14 PM   #7
J Drye's Avatar
I just got the TME Extrema charger and really like it. It can charge up to 10s Lipo, or up to 4s lipo at 8amps. It is also upgradeable via USB cable and the internet to help prevent it from becoming obsolete. It has an adjustable timer on it to setup a maximum charge time limit and a temperature probe on it so if the battery gets to hot it automatically shuts down. There is a built in watt meter as well that can tell you what your peak amp draw is, your maximum horsepower you are getting from your motor and temp of the motor. You can adjust the amount of voltage from 3.6V to 4.2V so you can charge A123 batteries with it. You will still need a power supply with it though. The Extrema can also charge multiple batteries at the same time as well.
http://www.tmenet.com/xtrema.htm
J Drye is offline   Reply With Quote
Tekno Conversions Thread teknorc Electric Off-Road 10250 01-30-2017 02:30 PM
New Rockingham track - On and offroad KingBob Australian Racing 88 09-15-2015 07:33 PM
10th touring losing popularity? ESmith Electric On-Road 100 02-11-2009 07:25 AM
Need help? Amphibious rc car sk11dn Australian Racing 28 10-09-2008 10:52 PM
Need help on electric car motor. 6T?..10T?..17T? azmin Malaysian R/C Racers 14 09-13-2007 07:32 AM
Help selecting a car kit...... spmiz Rookie Zone 26 08-25-2004 04:55 PM
