Old 11-28-2003, 09:59 PM   #1
LosiFromHell986's Avatar
Send a message via AIM to LosiFromHell986
Default Good Charger for around $50-$60? PEAK
Whats a good PEAK charger for around $50-$60? I need a new, up-to-date charger. NiMH and NiCD charging.
LMK
(I need to update, I have an OLD (1991) Timer charger w/adjustable current) Luckily I dont have any exspensive batts!
LosiFromHell986 is offline   Reply With Quote
Old 11-28-2003, 10:32 PM   #2
speedydave's Avatar
Send a message via AIM to speedydave Send a message via Yahoo to speedydave
MRC Super Brain 959...$46 at Tower, and the only problem I've heard of is it gets a little warm when charging, so it's helpful to keep a fan pointed at it during charging, or, if you want, I can find a how-to article on putting a fan in the charger for you, if you decide to get it.
speedydave is offline   Reply With Quote
Old 11-28-2003, 11:42 PM   #3
thanks speedydave, I'm actually asking for it for christmas, , so I'm not sure i'll get it. Either that or the Black widow Pro. any problems you know of for those?
Old 11-29-2003, 11:17 PM   #4
the superbeain has a heat problem so to keep it in top shape install a fan
losi4life is offline   Reply With Quote
Old 11-30-2003, 01:24 PM   #5
wild gopher's Avatar
Trader Rating: 39 (100%+)
the dynamite prophet plus is also a good peak charger around the $50 range
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 11-30-2003, 03:52 PM   #6
Hey where can I find the Dynamite Charger?
Old 11-30-2003, 04:15 PM   #7
you can find it at http://www.horizonhobby.com/
Old 12-03-2003, 05:26 PM   #8
Send a message via AIM to MAXXimumSPeEDx
I'd get the DuraTrax IntelliPeak AC/DC Pulse Charger.
1) It's 52.99 (on towerhobbies.com)
2) discharges and charges NiCd & NiMH (only Sub-C Cells)
3) Know a friend who has it and hasn't had trouble with it (says charger gets a little warm to hot sometimes [keep a fan near vents to cool off])
4) Can change amount of amps on type of battery:
(NiMH = 0.5A - 3.0A)
(NiCd = 3.1A - 6.5A)
5) Choice of Slow Charge, Peak Charge, & Discharge
6) Can charge 4 - 8 Cell NiMH/NiCd batteries
Sounds good, but just my opinion, go with whatever you want, just felt like putting my 2 cents in .
MAXXimumSPeEDx is offline   Reply With Quote
Old 12-03-2003, 06:05 PM   #9
whats the difference between a Peak Charger and a Pulse Charger?
Old 01-14-2004, 07:01 PM   #10
Send a message via Yahoo to the shoe
when we talk about a peak charger we are talking about the chargers ability to detect when the battery has reached a full charge (peak) and stops charging.Pulse charging is how the charger delivers the charge to the batt,as in a pulsing wave.The other type of charging is called linear and in that case the charge is delivered at a steady rate the whole charging period(constent). Other types of chargers are Timed, when a set time is reached the charger stops charging,and Tempiture in this case the charger has a probe that sences the tempiture of the cell and stops charging at a predetermined temp. Hope this helps clear things up for you on types of chargers and types of charge.
the shoe is offline   Reply With Quote
Old 01-14-2004, 09:14 PM   #11
rcgod's Avatar
Trader Rating: 27 (100%+)
I've got a Superbrain 959, and right out of the box it false peaks on 6 cell 3000 and 3300 mah batteries. It charges 5 cell and 1 cell fine.
rcgod is offline   Reply With Quote
Old 01-17-2004, 10:22 AM   #12
Paranha digi pro is up there in features and at a very good price $60 I have one and it works fine .
Old 01-18-2004, 02:43 PM   #13
I wouldnt get one of those I had one that I used to charge batts a few years ago when I was just getting into rc and later used to charge rx batts, but somthing went wrong with the AC part of the thing, and now it blows the fuse no matter what the second I plug it in. It still works if I hook it up to my starter box battery though. It also only charges up to 3 amps without a power supply.
AE Racer is offline   Reply With Quote
WTB Good peak charger Rocket XUT R/C Items: Wanted to Buy 10 02-23-2008 01:16 PM
Piranha Digital Peak Charger - Good or not? Johnathan Rookie Zone 4 01-15-2007 12:18 PM
looking for a good deal on a nimh peak charger Tweaked R/C Items: Wanted to Buy 1 08-13-2005 03:13 PM
Need a good PEAK Charger!! True R/C Racing R/C Items: Wanted to Buy 0 12-23-2003 09:30 AM
Looking for a good peak charger for a good price....... DJ_GenR8 R/C Items: Wanted to Buy 8 01-31-2002 09:51 PM
