Old 03-23-2009, 08:01 PM   #1
heeltoedrver's Avatar
Default CORR Help
well i have been in the nitro game for a little while but electric is as new to me as it gets so lets say i want to run a sc10 brushless spec on lipos. what sort of speed should i expect? how about run time? how do i charge the lipos? can i get a charger that plugs into the wall? any and all help is more than appreciated!
Team Terribles
heeltoedrver is offline   Reply With Quote
Old 03-23-2009, 08:07 PM   #2
You will need a balancer, such as the Astro Blinky balancer, and for AC charging, everyone recommends the Onyx 230, which I might be getting. Basically set to charge at 1C (mah/1000), and keep an eye on it. Plug the balancer into the battery as you charge, and you are pretty much set.
LRP Z.28R - 3
Spur Gear - 0
howtowakeakar is offline   Reply With Quote
Old 03-23-2009, 08:09 PM   #3
Suspended
Since the truck's not out yet any guesses would be mere speculation.
Without specific questions about motor and battery combos you're considering it's hard to say.
You might want to try reading some of the threads on lipo and brushless.
Lightin' is offline   Reply With Quote
Old 03-23-2009, 08:27 PM   #4
i figured that was going to be the response, i should have said 2s 35c 5000mah lipo powering a 13.5t brushless. i know that the truck is not out, so in a slash what would this do?
Team Terribles
Old 03-24-2009, 09:15 AM   #5
Rick Hohwart's Avatar
The way the proposed rules for the SCT (trucks class with Slash and SC10) class read you the motor required is a 17.5 brushless or 27t stock motor. With this you caqn use a 2S 7.4V LiPo battery.This speed is more than enough for these trucks with the standard tires and typical tracks.
If you are not racing, a 13.5 would be very fast. i have used this as well but the slower speed of the 17.5 results in faster lap times on my local track.
I have been running the SC10 with the LRP 17.5 and 5000 20C battery. After a 5-minute race and upon recharging the battery, I add between 700mAh and 1100mAH. Without stopping, I could get probably get 15 minutes comfortably and likley up to 20 minutes.
I can't give an idea of truck speed as in a racing environment your speed is your lap time. Actual MPH does not matter.
There is a good AC/DC charger by Dynamite that plugs right in and charges LiPos. I would recommend this, and an LRP Sphere ESC with an LRP 17.5 stock spec motor. You will probably get many suggestions about other motors and ESCs but a sensored type like the LRP (or others) gives the best throttle feel and drivability so at least stick with the sensored type.
Rick Hohwart is offline   Reply With Quote
Old 03-24-2009, 07:57 PM   #6
TfnG's Avatar
Trader Rating: 26 (100%+)
the hyperion eos0606i is a nice lipo charger...and has a balancer built in.
TfnG is offline   Reply With Quote
Traxxas Slash spec class racing at Ryde in 2009 and beyond Roman Australian Racing 2293 02-20-2013 06:18 AM
New Traxxas Slash 1:10 Electric CORR Truck salteen Electric Off-Road 3949 03-19-2012 09:24 AM
Losi Strike CORR SCT liljohn1064 Electric Off-Road 1710 11-19-2010 01:05 AM
SC10?!? trdsupra88 Electric Off-Road 926 07-20-2009 01:29 PM
It's Official... ROAR SCT (Short Course Truck) Class ifuonlyknew Electric Off-Road 241 06-27-2009 09:40 AM
1/8 buggy to CORR truck conversion Shark413 Electric Off-Road 18 11-18-2008 06:26 PM
