Old 03-23-2009, 01:19 PM   #1
Trader Rating: 31 (100%+)
Send a message via Skype™ to vstrok
Default NiMh / Tape??
What is safe tape to use to hold these guys together? Standard electrical tape ok??
Ofna GTP2e - Tekin RX8 / Tekin 2250 kv
Ofna Hyper 10SC - MM Pro / Castle 6900 kv
Ofna Hyper 10TT - MM Pro / Tekin SC4X 5.5T
vstrok is offline   Reply With Quote
Old 03-23-2009, 01:22 PM   #2
If you are talking about side by side configuration, strapping tape works best. Electrical tape is too stretchy...
richard.bratton is offline   Reply With Quote
Old 03-23-2009, 01:22 PM   #3
RC TTwins's Avatar
Trader Rating: 43 (100%+)
if ur looking to hold cells together GOOP works much better u can pick it up at a hardware store also walmart has it too.
RC TTwins is offline   Reply With Quote
Old 03-23-2009, 01:31 PM   #4
Deafinatly Shoe Goo when you build the pack and if possible use some heat shrink around the pack. If you need to ballance the pack just sut out the ends for access to terminals for discharge and ballance.
robert simmons is offline   Reply With Quote
Old 03-23-2009, 01:32 PM   #5
I'm not building a pack. One of my stick packs kinda came apart a bit, but the electrical connections are ok...
Old 03-23-2009, 01:34 PM   #6
In that case, just wrap it with electrical tape. That should insulate it and keep out the elements just fine.
Old 03-23-2009, 03:40 PM   #7
Trader Rating: 21 (100%+)
I'd put a bead of shoe-goo between the cells than came apart and then reinforce th epac with strapping tape. New heat shrink would be next. Better than new....
Duster_360 is offline   Reply With Quote
Old 03-23-2009, 05:40 PM   #8
clear individual cell shrink, then you can use CA glue to hold the cells in place.......
QUICK and your done !!!!
jtodd is offline   Reply With Quote
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Li-Awesome Vs. Li-sux TeamButter Electric On-Road 117 10-29-2007 07:51 PM
WARNING! rcmark24 Electric On-Road 57 09-12-2007 08:46 PM
Stock motor(27turn) touring car-- lipo's and nihm's Joel Lagace Electric On-Road 15 04-10-2007 06:09 PM
How you dispose your old batteries/ batery packs Car Breaker Electric On-Road 15 06-01-2006 07:53 PM
