Old 03-22-2009, 01:17 PM   #1
tinknocker81's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to tinknocker81 Send a message via Yahoo to tinknocker81
Default Lipos and e-revo
Does anyone know if the hard cased lipos with the power leads comeing out the top will fit in the e-revo battery compartments? I want to buy a pair but want to make sure they will fit. Thanks!
tinknocker81 is offline   Reply With Quote
Old 03-22-2009, 01:52 PM   #2
Trader Rating: 21 (100%+)
I just got a pr of hard cased and they are small - about size of a 6 cell shotgun pack. Mine measure 25mm x 137mm x 46mm. They even fit in my 3906 Emaxx batt tray.
ERevo batt compartment supposed to allow batts up to 30mm x 160 x 51mm -
see pic in #16
http://monster.traxxas.com/showthread.php?t=430233
Duster_360 is offline   Reply With Quote
Old 03-22-2009, 01:55 PM   #3
Default thanks
So even after you put the banana clips in the top they still fit?
Old 03-22-2009, 02:19 PM   #4
On these Intellects, the banana plug sticks up an additional 4mm. Where the plugs are located, that part of the batt is reduced in thickness and the diff is taken off the top surface. I put 12ga wet noodle on for wiring and that would have to be squeezed in to fit. Smaller gage wire wouldn't be quite the prob.
I know you can get the bigger plugs (5.5 and 6mm) with a hole in the side for soldering connection at 90degrees. These that came with mine didn't have that, but that doesn't mean they're not available or you couldn't drill your own holes to make 90degree solder connection.
If other hard cased lipos don't have this recessed area where the banana plugs are, these will be too tall across the plugs to fit.
Old 03-22-2009, 02:34 PM   #5
Default thanks
sweet thanks for the help.
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 08:26 PM
Jammin CRT .5 = 1/12 Truggy Team Kamikaze Nitro Off-Road 2269 07-02-2017 05:32 PM
SPC 2S2P 8000mAh LiPo healthyfatboy R/C Items: For Sale/Trade 11 04-24-2009 10:07 PM
Core RC 5000mah Lipos... Nexus Electric On-Road 615 11-05-2008 08:03 AM
Traxxas Slash Spec Class at OC/RC WisdomRacing Electric Off-Road 131 06-29-2008 11:28 PM
e-savage rtr xxx-ntad2 racer Monster Trucks 19 09-11-2007 01:39 AM
