Old 03-22-2009, 03:15 AM   #1
Send a message via MSN to KROGOTH
Default Handling Adjustments
What kind of adjustments can I may to my Bandit to improve high speed handling? It has no problem making turns at low speed but once I let loose on the throttle, its more like Im simply suggesting the car go in that direction but its really up to the Bandit.
The conditions I normally drive it on is gravel or loose/packed dirt and everything is still stock on the car itself.
Any suggestions?
Traxxas Slayer
(can i haz races nao?)
HPI Baja 5B
(~current pride and joy~)
Traxxas Bandit (in pieces and abandoned)
KROGOTH is offline   Reply With Quote
Old 03-22-2009, 03:26 PM   #2
JeromeK99's Avatar
The Bandit is a great basher, but is not known for good handling. It really depends on traction and motor... with buggies in general you need to slow down for turns and sometimes use the brakes before entering them.
You also need tires to match the ground conditions. Mostly changing the rears to meet your needs. If the rear tires have too much traction, then you will tend to "push" in the corners(wheels turn but car doesnt).
Remember too that trucks and buggies handle very differently.
Jerome
JeromeK99 is offline   Reply With Quote
Old 03-24-2009, 04:30 AM   #3
Yeah Ive noticed that it handles better at low speeds, but Ive been playing with the front suspension, trying different spacers on the spring on the shock and switching between the two positions on the stock A-arms.
Currently I have the stock tires still. When I go on R&R in a month or so, tires are on my list of R/C parts to bring back with me. Right now I dont get hardly any push, especially not on the few paved areas of my motor pool. Unless I go real easy on the throttle, prepare to fishtail in place. lol.
Ive not driven any trucks, though so I cant really compare how they handle or whatever.
Once I have my aluminum shock towers, Im going to try out different positions for the front shock, and continue to try different spring tensions to try and keep the front tires down. So far my efforts in regards to that have only cause the front end to just bounce into the air. Bleh.
Traxxas Slayer
HPI Baja 5B
Old 03-24-2009, 04:27 PM   #4
JeromeK99's Avatar
Maybe try a softer spring in the front to lessen the rebound.
Jerome
Team Associated TC5 RCknight Electric On-Road 13256 Yesterday 05:13 PM
Tamiya TA05 Touring Sedan kentech Electric On-Road 11403 06-21-2017 04:10 AM
Rc10ntc3 Taz_S Nitro On-Road 9437 05-28-2017 09:13 PM
Xray T1 David Galdo Electric On-Road 12705 07-04-2016 02:07 AM
1/10 Formula 1 Car Forums kuanseng1981 Singapore R/C Racers 4449 07-25-2015 12:28 AM
How changes affect handling on an Associated vehicle ckaspar Electric Off-Road 13 04-14-2009 11:10 AM
