Old 03-20-2009, 07:27 AM   #1
Default 8ight steering problem
Just purchased an 8ight (used) that I converted to brushless. When I turn the wheels to the left they do not return all the way to center. the same thing happens when I turn them to the right. When I disconnect the servo, and check the steering linkage, there is no binding. End points are set correctly. If I try this with the buggy off the ground, it appears to center OK. I have tried 2 different servos, both good, with over 200 oz. of torque.
any ideas?
warbunny1 is offline   Reply With Quote
Old 03-20-2009, 07:43 AM   #2
jimcoracer's Avatar
What speed control are you running? Are you running a external BEC? What brand servo are you using...it might be drawing to much power. Have you tried running a power cap on your reciver?
Brian_R
AWDpawnz
RS25.com
NASIOC.com
jimcoracer is offline   Reply With Quote
Old 03-20-2009, 08:22 AM   #3
What size is the power cap? Who makes it (Novak, Spektrum)?
Thopper is offline   Reply With Quote
Old 03-20-2009, 08:59 AM   #4
MMM combo, no external BEC. I tried both Hitec and JR servos. Both work fine in my 8ight T with the same MMM combo.
Old 03-20-2009, 09:00 AM   #5
I'm also running a Nomadio reciever.
Old 03-20-2009, 10:15 AM   #6
badassrevo's Avatar
Make sure the servo saver is tight. you should see at least 5 threads below the nut.
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 03-20-2009, 11:11 AM   #7
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
http://www.amainhobbies.com/product_...oducts_id/6570
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 03-20-2009, 09:12 PM   #8
That's what I was going to say. I loosed the servo saver a little too much and had the same problem. Tighten it up enough that you don't have the excessive play but can still manually turn the wheels without excessively jarring the servo.
Ryandrea is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 08:58 AM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 09:43 AM
LST Super Truck RTR w/XS3 & Mach .26 rcindebt R/C Items: For Sale/Trade 11 03-05-2009 12:12 AM
Steering problem on my Losi 8ight RcOneNitro Nitro Off-Road 12 08-11-2007 09:22 AM
