Old 03-18-2009, 10:23 PM   #1
Default anyone make aluminum mod 1 pinions? can i convert my 8ight buggy to 32 pitch?
i'd like to convert to 32 pitch because then i can get aluminum pinions from castle creations
2jim1 is offline   Reply With Quote
Old 03-19-2009, 09:19 AM   #2
ta_man's Avatar
Trader Rating: 151 (100%+)
You obviously don't know it yet, but you really don't want aluminum pinions on electric 1/8th scales.
I had a Centrury steel pinion wear out running against a Kyosho plastic spur. You would probably have to change your aluminum pinions every heat. (slight exageration, but only slight.)
ta_man is offline   Reply With Quote
Old 03-19-2009, 10:59 AM   #3
whitrzac's Avatar
Trader Rating: 96 (100%+)
most of the mod 1 pinions are aluminum, but there hardend...
whitrzac is offline   Reply With Quote
Old 03-19-2009, 11:29 AM   #4
kufman's Avatar
Aluminum pinions don't work well for 1/8th buggies. They will only last a couple of runs if you are running a metal spur and not much longer with plastic spurs. Hardened steel pinions were a huge improvement when they finally came out.
kufman is offline   Reply With Quote
Old 03-19-2009, 12:23 PM   #5
well i'd like to try it
i had aluminum in my e-revo brushless that has way bigger tires and it didn't have any problem
and i don't think that most 1/8 pinions are aluminum and that they are just hardened since most of the ones i have seen advertised say hardened steel
please keep the information comming though
Old 03-19-2009, 06:39 PM   #6
ta_man's Avatar
Please point out two brands intended for RC use - showing manufacturer's description that they are aluminum. If "most" are aluminum, it shouldn't be too hard to show us two brands.
Old 03-19-2009, 07:03 PM   #7
kufman's Avatar
Why do you want to try aluminum?
Old 03-19-2009, 07:41 PM   #8
Kings Kid's Avatar
Trader Rating: 35 (100%+)
2jim,an 1/8th scale electric is alot harder on the drive system the an e-revo. No slipper and lots of torque. There's really no advantage and two distinct disadvantages I can think of:1) aluminum shavings all over inside my buggy, 2) less money in my pockets!
Kings Kid is offline   Reply With Quote
Old 03-19-2009, 08:44 PM   #9
thats funny. i just like having lighter parts and a lighter drive train for more efficiency and i think that aluminum ones are way cooler
i will say that the plastic spur in my 8ight-E is way cooler than the metal one that i had cause it is so much quieter and smoother sounding, although it stis closer to the motor mount so i had to grind my motor mount down some so that the pinion doesn't hit
thanks for the info
Old 03-19-2009, 09:27 PM   #10
kufman's Avatar
thanks for the info
Most of the drive train weight in a 1/8th buggy is in the diffs. If you can make the diffs lighter, you might have something worth while.
