Old 03-17-2009, 08:33 PM   #1
triggerman101's Avatar
Trader Rating: 102 (100%+)
Default what do i need for 1/8 buggy b/l conversion
i have a mbx5r and im wanting to go brushless. i found a novak conversion kit and im thinking about a novak hv system or a mamba system. dont know which yet. i have no idea where to start with looking for batteries. i know lipo's but do i need 1 or 2?
my questions are:
which brushless system should i go with
do i need 1 lipo or 2. im lost in the lipo department
thanks for any help in advance.
Mbx7r, mbx6t(still)
dialedhobbies.com
AKA, James, 4px, Hitec
triggerman101 is offline   Reply With Quote
Old 03-17-2009, 10:04 PM   #2
Trader Rating: 254 (100%+)
I would use the mamba monster and 2 2cell 7.4v lipos of at least 5000mah or more.
92 vert is offline   Reply With Quote
Old 03-18-2009, 01:52 AM   #3
SpEEdyBL's Avatar
FYI, the Novak conversions will only work with Novak motors. Better to find out now than later...
Otherwise i would recommend the Mamba monster for a different converion kit.
My vehicles (that work):
Custom experimental Losi 810/TEN SCTE - The fastest 1/8 scale buggy on the track - 5.2lb rtr - readily convertable to a ROAR legal 1/10 scale 4x4 SCT.
Custom Losi 8ight - lowest CG of any 1/8 buggy
Losi 22 Mid Motor
SpEEdyBL is offline   Reply With Quote
Old 03-18-2009, 06:02 AM   #4
badassrevo's Avatar
Check out this conversion from Caster Racing USA, www.casterracingusa.com
You will need to purchase the Caster mud guards too.
I would recomend the Castle MMM 2650 Combo or the Speed Passion 2200/2500 combo
and 2 2s 5000/8000 batteries depending on how long you want to run.
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 03-18-2009, 06:10 AM   #5
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
my questions are:
Like mentioned before hand, if you like novak products (I do)
buy the novak conversion and you will be set.
As for the lipos. if your buy a battery pack that is 2s you will need 2 of them as that is a 7.4 volt pack. If you buy a pack that is 4s you will need only one because that is 14.8 volts.
Personally I would buy 2 packs that are 7.4 each because they are more versitle when it comes to putting them into other trucks, buggies or cars. If you buy a 4s 14.8 volt pack your limited to an High Volt application only.
Original RC 10T, T4, RC8Te, Tekin RX8. Losi Ten SCTE, Slash 4x4.
OG RC 10T is offline   Reply With Quote
Old 03-18-2009, 07:43 AM   #6
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
You should email TonyScrews and see what he says. He ran the MBX5R conversion for awhile and can give you great info.
For the most versitality when it comes to different battery sizes, you probably would want the RC Product Designs conversion kit. Very high quality, and can take the long style packs like the Losi 4S hardcased packs.
The Caster Fusion conversion works excellent on the MBX5 and does a great job with weight balance.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 03-18-2009, 08:49 AM   #7
meauxjeaux's Avatar
Hi Cain.
Would you happen to have tonyscrews email?
I have a mbx5 prospec and I'm interested in the BL conversion also.
meauxjeaux is offline   Reply With Quote
Old 03-18-2009, 09:23 AM   #8
glassdoctor's Avatar
If anyone is interested in a Caster Fusion setup for their MBX5, you can contact me... I can hook you up. I know a few guys are running this on their Mugens already.
glassdoctor is offline   Reply With Quote
Old 03-18-2009, 10:05 AM   #9
Tech Legend
Cain's Avatar
his handle on here is TonyScrews.
Old 03-18-2009, 12:35 PM   #10
Do some homework over on RC-Monster. Those guys post a lot of conversions usually very detail laden. The Mamba Monster v3 is a really popular choice but I'll probably go with the HobbyWing 150A controller for my conversion (MBX5T).
Aceldama is offline   Reply With Quote
Old 03-18-2009, 05:19 PM   #11
thanks for the help guys. im trying to check out other options. i would probably go with one battery. im wanting to go brushless for the low hassle and enjoyment of the larger scales. im about ready to give up on them. wanting to try a brushless kit first. i was wanting to go with novak because ive had novak before and still have some novak stuff. the 410 is still working fine. i like that dependability. i also hear that they are under powered. which lets me think about that saying "dont build a rocket ship if you cant control it". which also would help with not breaking drive train parts. once i get used to it, ill want more power which can always be changed later. walking before running was the way i grew up so maybe that same thing would work in this case. i do like the better conversion kits with the chassis.
Mbx7r, mbx6t(still)
dialedhobbies.com
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
