Old 03-12-2009, 08:30 AM   #1
Default charging lipos?
can the onyx 230 charge thiss lipo??
http://www.hobbycity.com/hobbycity/s...idProduct=8580
bmxdude is offline   Reply With Quote
Old 03-12-2009, 08:50 AM   #2
I beleive the instruction say up to 3 cell lipos, so your answer would be no.
Jerry Coy is offline   Reply With Quote
Old 03-12-2009, 10:20 AM   #3
beastlyB44's Avatar
umm, i have the Onyx 230. the maximum is 3 cells, sorry. but i love this charger. for only 80 bucks you cant get more
VXL rusty
Mamba max 6900 bl w/ reedy lipo B44
Oh, and a little bit of stupid
Stock is never enough
beastlyB44 is offline   Reply With Quote
Old 03-12-2009, 10:32 AM   #4
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to y2kgtp Send a message via Yahoo to y2kgtp
Yes it can. However I do not see any sort of balancing ability of this charger, so the battery might get a bit out of sync after a few charge\discharge cycles.
"Yes my car is technically illegal, but still its either just as fast or slower than any other car on the track so whats the issue with it being illegal?"
y2kgtp is offline   Reply With Quote
Old 03-12-2009, 10:45 AM   #5
y2kgtp
Could you tell me how that is possible, as far as balancing you just have ti buy an external balancer, works just fine.
Old 03-12-2009, 11:00 AM   #6
y2kgtp's Avatar
Originally Posted by Jerry Coy View Post
y2kgtp
It states it can charge a 3 cell LiPo in the specifications. I agree, I would suggest getting a external balancer when in use with the battery.
Onyx 230:
Battery types: 1-8 NiCd or NiMH cells (1.2-9.6V)
1-3 LiPo, Li-Ion, or LiFe cells (3.7-11.1V)
Battery capacity range: 50-9900mAh
Fast charge current: 0.1-7.0A linear, adjustable
This might do better in the Radio\Electronics section
http://www.rctech.net/forum/radio-electronics-137/
Old 03-12-2009, 11:03 AM   #7
correct and the battery he has linked is a 4 cell Zippy pack. So I am not following you.
Old 03-12-2009, 11:10 AM   #8
TwoTone's Avatar
Onyx 230:
Not to be rude but you bother to read the linked batery?
Capacity: 5000mAh
Voltage: 4S1P / 4 Cell / 14.8v
Discharge: 20C Constant / 30C Burst
Weight: 503g (including wire, plug & shrink wrap)
Dimensions: 142x50x33mm
Balance Plug: JST-XH
Discharge Plug: 4mm Bullet-Connector
TwoTone is offline   Reply With Quote
Old 03-12-2009, 11:12 AM   #9
y2kgtp's Avatar
Capacity: 5000mAh
Woops, my mistake....I was looking at a similar 3cell one..... Sorry guys....
Old 03-12-2009, 11:16 AM   #10
sorry i should have put the spec up. so theres no way to charge it? what about if i make the pack into a 2s pack? could i make it a 2s pack and have 2 2s battereys then?
Old 03-12-2009, 12:15 PM   #11
R40Victim's Avatar
Yes you can... if you know where to look:
http://www.hobbycity.com/hobbycity/s...cer/discharger
It won't do Nimh, but who uses Nimh any more?
R40Victim is offline   Reply With Quote
Old 03-12-2009, 12:50 PM   #12
y2kgtp's Avatar
Your link says it does NiMH....
Old 03-12-2009, 12:58 PM   #13
y2kgtp's Avatar
Well, you could get 2 of these and wire together to get 14.8v:
http://www.hobbycity.com/hobbycity/s...idProduct=8578
Old 03-12-2009, 01:42 PM   #14
the onyx 230 does charge the Nimh
FEATURES: Charges 1-8 cell NiCd or NiMH (1.2 - 9.6V) cells and 1-3 cell LiPo,
Li-Ion or LiFe (3.7 - 11.1V) cells
Fully adjustable charge currents and multi-chemistry adaptability
for a wide range of applications
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
1st time charging lipos.. help with ICE set up sugelle Radio and Electronics 14 03-22-2009 01:33 PM
MaxAmps.com's Official Stance on pack heating and bumping.... JAM MaxAmps Electric On-Road 33 01-17-2009 07:53 AM
How do I charge lipo at 9.6A / Orion Carbon Advantage bigemike Electric On-Road 20 09-25-2007 07:50 PM
