How can i set up brake with Castle Creations Mamba Monster 1/8th Scale >
Old 03-11-2009, 08:42 AM
Questions?? How can i set up brake with Castle Creations Mamba Monster 1/8th Scale
It lock up my brakes as soon as I tapped the brakes.
my transmitter is DX 3R.
rutny is offline
Old 03-11-2009, 08:45 AM
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
You need to go to EPA in your radio. You will EPA for throttle and brakes. Once your in the EPA screen you will need to push you trigger forward as that will put you in EPA for the brakes. More than likely you will see the number 100. You want to lower this number to lets say 50. If you need more or less brake increase or decrease as need to get more or less brake.
wyd is offline
Old 03-11-2009, 08:51 AM
R40Victim's Avatar
You can also use "Exponential" to soften the brakes, or give them a more progressive feel. Play with the settings in your transmitter, you'll get it.
R40Victim is offline
Old 03-11-2009, 10:26 AM
I try to do Exponential 20% [push trigger forward ] brake 40% and push th forward [ travel ] 40%
It not to hight brake but it a little bit lock . If i set brake under 40% it no brake. what should i do or some one who can show me how many % do u
set up with dx 3r I run with SC8 .
thank.
rutny is offline
Old 03-11-2009, 01:51 PM
I got it , because i set up esc option 3 forward/brake/reverse . I change to option 1 reverse lockout . I just read manual again
thanks a lot.
rutny is offline
Old 03-11-2009, 02:06 PM
R40Victim's Avatar
thanks a lot.
Cool! You're in a minority man... NOBODY reads the manual anymore! They just rush into it, get stuck, and ask for advice online.
