Old 03-10-2009, 09:11 AM   #1
Trader Rating: 21 (100%+)
Default motor heatsink on 2wd ??
might be a stupid question for a 2wd buggy, but can you see any benefits in running a heatsink on the motor?
fastbynature is offline   Reply With Quote
Old 03-10-2009, 09:15 AM   #2
OTE_TheMissile's Avatar
Send a message via MSN to OTE_TheMissile
If you think you need it...
Faster Than Factory
On The EDGE Racing, est. 2001 - Home of the 524, the Silverado Slammer E-MAX6X6, and the Sand Dollar prerunner
Mike Budzien | facebook.com/OTE.TheMissile | RIVCO Products | The RC Corral | iRacing.com
OTE_TheMissile is offline   Reply With Quote
Old 03-10-2009, 09:18 AM   #3
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
if u need 1, then somethin is wrong w/the motor, gearing, and/or drivetrain. that and its just a hunk of weight behind the rear suspension. not good
R
UltegraSTI is offline   Reply With Quote
Old 03-10-2009, 09:22 AM   #4
im hearing people gearing their 17.5 to less then 4.7fdr so want a cooler motor
Old 03-10-2009, 09:26 AM   #5
Suspended
R
I guess you've never had the experience of a motor that just ran hot?
Lightin' is offline   Reply With Quote
Old 03-17-2009, 03:41 PM   #6
hyperguy's Avatar
Trader Rating: 22 (100%+)
not unless you are planning on running onroad!!!!!!!!!!!
hyperguy is offline   Reply With Quote
Old 03-17-2009, 04:08 PM   #7
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
our outdoor tracks here are soil so we run step pins mostly , and the high bite causes the 17.5's to run warm esp. in a truck, so I run 1 of the slim profile clip-on heat sinks.It works nice, 10* cooler temps over a 5 min. run.
I will post a pic of the heat sink.
*Vandal 4wd Late model*XXX-T sprinter*Micro scale specialties 1/24 'rock monster' crawler*MSS Micro-Rail*MSS Micro-Funny*MSS Micro-Outlaw*
2wdMod is offline   Reply With Quote
Old 03-18-2009, 06:42 AM   #8
do you have a link for that item?
I was looking at cutting one of my normal heatsinks in half otherwise to fit.
Old 03-18-2009, 07:14 AM   #9
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to y2kgtp Send a message via Yahoo to y2kgtp
How about a small fan instead?
"Yes my car is technically illegal, but still its either just as fast or slower than any other car on the track so whats the issue with it being illegal?"
y2kgtp is offline   Reply With Quote
Old 03-18-2009, 08:27 AM   #10
Most motor fans are mounted to a heatsink. I never really saw a problem with throwing a heat sink on there... and if your mostly a basher it's great insurance. If you feel that you NEEDa motor fan/heatsink combo on your car... then you should rethink your gearing, but if you just want it for a peace of mind then I say go for it.
Jay
~ Jason Kennedy ~
~ Sweep Racing Tires ~
~ TQ Wire~Wire~
pyro18t is offline   Reply With Quote
Old 03-18-2009, 09:05 AM   #11
hyperguy's Avatar
if you want to run a fan on the motor you may need to get the setup from a lrp tc spec. they have one for the motor that clips on
Old 03-19-2009, 07:29 PM   #12
dont think a fan is going to be of any help on a 2wd. I will be cutting a heatsink I already have in half to fit my rb5. Got it geared down to 4.3 now, and it already runs about 160 degrees at 5 min. The heatsink should bring it down 5-10 degrees.
Old 03-19-2009, 07:55 PM   #13
OK, I have to ask. When you guys are talking about being geared up to 4.3, are you talking about your final drive or roll-out? I currently run my B4 with a final drive of 5.4 (35 pinion, 72 spur) and that's the highest I can go, I can't find a bigger pinion, and even if I use my slipper-elim, I can only go to 4.8 (35 pinion, 65 spur). My temps with the 72 spur are about 100* after 5 minutes.
Jeff Robins
Associated B5M - Tekin RS - R1 WURKS 17.5 - Savox - Airtronics
Associated 44.3 - Novak Pulse - Novak 5.5 - Airtronics
ffejrobins30 is offline   Reply With Quote
Old 03-20-2009, 12:44 AM   #14
35/64, isn't that a high? It seems that would be just for top end, and wouldn't think that you would have any low end with that setup. Then again maybe I'm wrong?
J
~ Jason Kennedy ~
~ TQ Wire~Wire~
Old 03-20-2009, 08:08 AM   #15
They make pinions bigger than 35. Im using robinson racing 39t. 4.3 final drive. But that ratio is with a 17.5 brushless. You need to gear them high to get them going anywhere as they are low revvers. I thought around 5.5 was good, until I slowly went down and down, and have arrived at a nice ratio to run, even on a tight twisty track believe it or not. I'm running an rb5 with a 39 pinion and 65 spur. Do a search on "turbo hub". There is a guy on here who makes them. It allows you to run small spur gears on your b4, cr or rb5. I know some guys running 41t on their b4's.
Micro On Road & 1/18 Off Road Nats Thread RCMadness Micro and Mini Scales 1168 11-23-2017 08:19 AM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 02:13 AM
New ACADEMY 1/10 scale 2WD BUGGY rcforum Electric Off-Road 3794 09-30-2013 08:57 AM
Grade my B44 build! Zerodefect Electric Off-Road 25 05-07-2008 09:04 PM
Heatsink on LRP Sphere Competition Sneaky Pete Electric Off-Road 8 09-20-2007 05:12 AM
