Old 03-09-2009, 07:59 PM   #1
Nelstrodomous's Avatar
Send a message via Yahoo to Nelstrodomous
Default Help w/water logged tires?
Has anyone discovered a solution to water logged tires? I run my Slash in mud and water (my home track is primative) and the foam liners fill up with water. I'm running beadlock rims, so I can change tires easier.....is there any sort of a solid liner to replace the soft foam inserts? My theory is that with a solid liner that fills the inside of the tire, not as much (if any) water has any room to fill up the inside of the tire and they won't get so heavy and rob my battery power
Nelstrodomous is offline   Reply With Quote
Old 03-09-2009, 08:01 PM   #2
Lombax's Avatar
Punching a 3mm hole in the tires between the treads will allow water and dirt to be pushed out by centrifugal force.
Lombax is offline   Reply With Quote
Old 03-09-2009, 08:57 PM   #3
xDaRReLLx87's Avatar
It will also allow the foam in the inside to rot a lot faster But it will accomplish your goal. It may be better to poke holes in the tires with needles, so you don't take to much traction away and still let the tire remove it's self from holding water.
Hyper 9E 2000KV T8/RX8- 4S Turnigy 4500 mah
Ko ProPo EX-1 UR 2.4 ghz, Hitec-7950TH
xDaRReLLx87 is offline   Reply With Quote
Old 03-09-2009, 11:50 PM   #4
Gliptal's Avatar
The hole is going to make the foam rot faster? that makes no sense. The water is what is going to cause the foam to rot. Punching holes in the tire is common practice for 1/8 buggy tires, it has no effect on traction.
Gliptal is offline   Reply With Quote
Old 03-10-2009, 08:50 AM   #5
Suspended
In all my years at the track I have never seen a truck spewing roostertails of water because of the holes people put in tires.
Lightin' is offline   Reply With Quote
Old 03-10-2009, 09:20 AM   #6
OTE_TheMissile's Avatar
Send a message via MSN to OTE_TheMissile
Well lightin I think if your tires are full of water to that point I'd say you need to be a little more careful with your tires when you wash them
Yeah it might seem like punching vent holes in the tire would let dirt and water inside easier, but it just as easily gives it a way back out again. Running a hole in the rim shell gives dirt & water a place to get in but no way out. I boiled off a pair of 1/8th Buggy tires that wre only vented through the rim once because it felt like the foams had turned to stone. As soon as the glue bead of the tire started coming loose the pot of boiling water turned into a pot of boiling mud.
And if you're drilling holes large enough to affect the grip of the tread...ok that'd have to be like a 1/2" spade bit or something...
Faster Than Factory
On The EDGE Racing, est. 2001 - Home of the 524, the Silverado Slammer E-MAX6X6, and the Sand Dollar prerunner
Mike Budzien | facebook.com/OTE.TheMissile | RIVCO Products | The RC Corral | iRacing.com
OTE_TheMissile is offline   Reply With Quote
