Old 03-08-2009, 02:45 PM   #1
snowboard094's Avatar
Default slash stronger transmission gears??
I have a brushless slash on a three cell lipo and i am always busting the same part in my transmission the: Shaft Slipper Clutch Roll Pin. Is their any aftermarket gears that would make the transmission more beef? I have seen the aluminum gearbox case but no stronger gears.
-Electrical wiz-Let me check your shorts.....that came out wrong
"Team Terrible"
Ofna Hyper 10sc
T-maxx O.S .18tm
snowboard094 is offline   Reply With Quote
Old 03-08-2009, 04:13 PM   #2
Trader Rating: 14 (100%+)
A friend of mine has a similar problem, and used a hardened pin (Team Associated part) in the transmission to keep that from happening.
Apologies that I do not have better information, but I would recommend taking the sheared pin and transmission to your hobby shop and approximate the size with the Team Associated equivalent part.. it is a hardened pin (not a roll pin)
Also happens much less frequently after loosening the slipper clutch to allow a little bit of slip with that much power. The Differential is the next weakest link, and we have shredded Diff gears as well. The Traxxas rustler transmission (used in slash) is one of the oldest and most bashed transmissions EVER and the beef of the gears is not really an issue.. you broke a cheap little part that kept you from shredding a diff.
Good luck!
Seyruuen is offline   Reply With Quote
Old 03-08-2009, 04:38 PM   #3
ok i will look into the AE part thanks. And yes my slipper was a bit to tight
"Team Terrible"
Ofna Hyper 10sc
T-maxx O.S .18tm
Old 03-08-2009, 05:07 PM   #4
streetracer745's Avatar
Send a message via AIM to streetracer745
There is a slash trhead which would be great for you... And considering everything you break are driveline parts, id say loosen your slipper. itll make it easier to control, smoother, and you wont break stuff all the time.
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 03-08-2009, 05:51 PM   #5
yeah i didnt think it was that tight but when i took off the gear cover and checked it it was.
"Team Terrible"
Ofna Hyper 10sc
T-maxx O.S .18tm
Old 03-08-2009, 05:56 PM   #6
nitrotruckn's Avatar
Send a message via Yahoo to nitrotruckn
Our findings thus far have been that the Slash truck leaves the factory with the slipper nut tightened all the way down. The manual suggests starting at 1 turn out from tight and go from there. A tight slipper probably caused your pin breakage.
"For God so loved the world..." John 3:16
Team FCA Endurance
Hammer Nutrition
Team RFC- chaplain (racers for Christ)
nitrotruckn is offline   Reply With Quote
Old 03-08-2009, 06:28 PM   #7
yeah most likely
"Team Terrible"
Ofna Hyper 10sc
T-maxx O.S .18tm
Associated Off Road Desert Truck ? Good Beer Electric Off-Road 541 08-19-2008 09:58 AM
