Old 03-07-2009, 10:38 PM   #1
function>form's Avatar
Trader Rating: 44 (100%+)
Default wtf is wrong with this spektrum
turn on reciever with bind button pressed in flashes as suppose to...same with transmitter...but when transmitter turns solid the reciever led just goes out..it wont bind and i gotta race in the am... help me out night owls....
function>form is offline   Reply With Quote
Old 03-08-2009, 12:31 AM   #2
nib
i had the same deal and it was a bad reciever
nib is offline   Reply With Quote
Old 03-08-2009, 12:37 AM   #3
SWTour's Avatar
..just for yucks (if you haven't already) turn the OTHER one on first and try again....and make sure the radio isn't in PCM mode (I've seen that a couple times too)
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 03-08-2009, 05:24 PM   #4
its an m8...so its not possible to be in pcm mode correct?
Old 03-08-2009, 06:35 PM   #5
Trader Rating: 15 (100%+)
Default Voltage
On the Dx3R I've had a low voltage issue on the TX so I just replaced batteries and it worked.
uncle everett is offline   Reply With Quote
Old 03-08-2009, 07:09 PM   #6
xDaRReLLx87's Avatar
Yes, the spektrum systems are very sensitive when it comes to low voltage. If they go below 4.6V they will reset and go berserk and other countless bugs.
I use a voltage regulator at 6.9V in my electric, and a 7.2-6.9 V battery pack for my nitro cars.
Hyper 9E 2000KV T8/RX8- 4S Turnigy 4500 mah
Ko ProPo EX-1 UR 2.4 ghz, Hitec-7950TH
xDaRReLLx87 is offline   Reply With Quote
Old 03-08-2009, 08:20 PM   #7
trickedyfz450's Avatar
Hey Josh I guess since you didn't make it to the track today that means you didn't figure it out?
Bumps And Jumps Rc
trickedyfz450 is offline   Reply With Quote
Old 03-08-2009, 08:38 PM   #8
yea man the thing is brand new,i messed with it for like 2 hours last night and i was just so frustrated with it that i just didnt feel like messing with it today.....
Old 03-09-2009, 12:48 PM   #9
That sucks!!! I had the same problem with my 3PK but it was the pcm mode problem.
Bumps And Jumps Rc
Old 03-09-2009, 12:55 PM   #10
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Funny as I had the smae problem when I first was setting up my new 3PK the other night but I remembered to check it after the first minute or two. I was irritated before I I changed it to PPM mode as then it was all good.
ST Racing Concepts (STRC)
Old 03-09-2009, 01:00 PM   #11
Yeah whats that pcm mode for anyways?
Bumps And Jumps Rc
Old 03-09-2009, 01:14 PM   #12
wyd
Tech Legend
wyd's Avatar
PCM was back in the day the next step above regular FM and was the glitch proof setup back a few years ago. If you ran PCM mode from Futaba you where as safe as it could be against glitching. It still is excellent if your on a really tight budget and thats all you have as it is better than regular FM.
Spektrum allrc Radio and Electronics 2545 07-17-2012 09:25 AM
