Old 03-05-2009, 08:42 PM   #16
Trader Rating: 31 (100%+)
Send a message via Skype™ to vstrok
Originally Posted by snowboard094 View Post
if you are just out for bashing you wont need anything more than a vxl. This is a very simple brushless system to set up and can propel your slash on a 3-cell lipo to over 60+mph. Mamba motors are more for racing because of such great programmability and tuning.
Bashing--vxl
Racing--Mamba 4600
Aight dude...with the VXL setup what will my avg run time be??
vstrok is offline   Reply With Quote
Old 03-05-2009, 08:46 PM   #17
snowboard094's Avatar
What battery would you be running?
-Electrical wiz-Let me check your shorts.....that came out wrong
"Team Terrible"
Ofna Hyper 10sc
T-maxx O.S .18tm
snowboard094 is offline   Reply With Quote
Old 03-05-2009, 08:53 PM   #18
3 cell lipo....whichever one would get me the longest run. Recommend??
Old 03-05-2009, 08:58 PM   #19
I run the poly rc 11.1v 4500mah 30c lipo. I get around 40min even when i am hard on the throttle. It makes the vxl slash INSANE!!! You can't keep the front wheels on the ground.
http://www.rclipos.com/PolyRC30C.htm
"Team Terrible"
Ofna Hyper 10sc
T-maxx O.S .18tm
Old 03-05-2009, 09:00 PM   #20
wow! that long a run time, huh?! thats great....thanks for the help!!
Old 03-05-2009, 09:04 PM   #21
http://www.rcboca.com/lipo-5000hv-3s-11.1v-pack.html
Also check this one out if you have the $$. Its made for the vxl system.
"Team Terrible"
Ofna Hyper 10sc
T-maxx O.S .18tm
Old 03-28-2009, 06:14 PM   #22
Default VXL Owners - Please Help
Not sure if this is the correct forum, if not I apologize... :/
Just got a new VXL 3s System for my Slash.
I am currently running my VXL on a Racer's Edge 2s 5000mAH LiPo with stock Slash gearing and pretty much everything else stock except for shock upgrades and a new transmitter / reciever.
After a full charge on my Racer's Edge SC2000 getting exactly 5000mAH into the pack using the balance charge setting and using the balancer lead to charge and balance the pack, I go out to run my truck in an empty gravel parking lot...
After about 15 minutes of light bashing, the Slash stops running and the LED on the ESC was blinking red.
Now I did not have the manual with me at the time so I did not know there was a difference between fast blinking and slow... however the Slash just stopped responding period, so I am assuming it was the Thermal Shut Down that kicked in and not the Low Voltage Cutoff ...
( Does this sound correct? )... because I did not get the 50% power stage, just bam.. nothing ..
It was about 65 degrees out where I am at and I also have the Traxxas Fan on the ESC running at all times.. I am not sure how it could have been the Thermal Shut Down when the sides of the ESC's heat sink did not even feel hot and the motor was warm but not so bad that I could not hold my thumb on it.
Thanks in advance for anyone that can help me diagnose this problem, and let me know if you need any more info. Once again, sorry if this post is in the wrong place.. :/
-- Neuromancer
Neuromancer is offline   Reply With Quote
Old 03-28-2009, 06:40 PM   #23
Justpassedu's Avatar
Trader Rating: 115 (100%+)
wrong place to post but i know what your experiancing , you prob have a problem with the speed control and need to send it back to traxxas , turn off the low voltage cutoff i think you have to hold the button down for ten seconds and youll have a red light on instead of green but also be carefull not to let your battery go down too much or it will be toast man. its a known vxl problem but i bet if you try it with the low voltage setting offf it will run much better.
Justpassedu is offline   Reply With Quote
Old 03-28-2009, 06:45 PM   #24
jd267's Avatar
Trader Rating: 36 (100%+)
mamba 5700 system rules in my slash... i run a smc 5200 2 cell 24c pack.. with a 15 tooth pinion and stock spure and its sick... motor stays cool also... it pulles the front tires on command.... and will run a 3 cell lipo.. castle says the 5700 is there fastes motor on 3 cell...
jd267 is offline   Reply With Quote
Fastlane Raceway kansasracer Kansas/Missouri Racing 17302 11-12-2017 03:30 PM
Electric Offroad at Pegasus Hobbies!!!!!!!!! Jeremy Felles California Racing 12184 10-20-2017 09:34 PM
New Traxxas Slash 1:10 Electric CORR Truck salteen Electric Off-Road 3949 03-19-2012 09:24 AM
Traxxas Velineon system. insane or lame? streetracer745 Electric Off-Road 76 12-30-2010 11:57 PM
FS/FT Slashes, Evaders, Brushless systems Manatarms25 R/C Items: For Sale/Trade 14 08-13-2009 08:31 AM
For those of you with a Slash class.... fiveoboy01 Electric Off-Road 88 12-04-2008 03:59 PM
Trade for Traxxas Slash mastangs64501 R/C Items: For Sale/Trade 49 11-07-2008 01:07 PM
