Team Associated RC8Te Thread >
Old 04-22-2012, 03:54 AM
  #586
DaveW's Avatar
Oh... the track was tight early on in the day, so i ran bronze rear spring, outer shock positions on tower AND arm. Front was silver spring, in on arm and out on tower. It jumped beautifully and gave me plenty of turn in for the first qually. It sucked ass in the main tho. LOL
Silver rear spring with a tire change would have been the ticket... along with leaving my ESC/motor changes for practice day.
DaveW is offline
Old 05-01-2012, 07:33 AM
  #587
Trader Rating: 29 (100%+)
i just wonder anyone see a new rc8t.2e truggy at rcx show yet?
taztal3 is offline
Old 05-01-2012, 07:46 AM
  #588
hoofer's Avatar
Trader Rating: 40 (100%+)
+1
hoofer is offline
Old 05-01-2012, 03:42 PM
  #589
Suspended
Trader Rating: 2 (75%+)
well look like i be given up the e truggy dream since hardly anyone keen now
will be selling it and go to a other brand now good while i had it
Zangetsu is offline
Old 05-04-2012, 12:26 PM
  #590
DaveW's Avatar
I drove an MBX6 nitro truggy and was sad at how crappy my 8T felt in comparison.
It was my first time at that track, and i got TQ and finished well... but if i had my electric setup in that nitro truck... i really think i coulda broke the track record with ease... i missed it by 3/10ths.
Out came the Dremel tool and i ordered some more FRP. The 8T is undergoing a transformation...
I also tried 7/5/3 in the diffs with less power... and was happier with the feel. I still need to sort out the ESC settings, but its a work in progress. Hopefully what i do here works with the 8B as well...
DaveW is offline
Old 06-12-2012, 05:29 PM
  #591
Trader Rating: 62 (100%+)
I got one. Can anyone direct me to the latest setup? Thanks
sipaboy is offline
Old 06-12-2012, 10:15 PM
  #592
DaveW's Avatar
You can look at the setups on AE's website for a good starting point. I can share mine if ya like...
DaveW is offline
Old 06-13-2012, 08:19 AM
  #593
do you think that kyosho spring or losi spring or any brand of spring will work on rc8te truggy ? i just want know it that all
taztal3 is offline
Old 06-13-2012, 08:35 AM
  #594
DaveW's Avatar
Thats a good question. I wouldnt mind a few optional spring rates myself...
DaveW is offline
Old 06-13-2012, 09:49 AM
  #595
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Kyosho, Mugen, and Losi are 15mm bore shocks. Associated and Hot Bodies use 16mm bore shocks.
I haven't tried it, but my guess is that the 15mm shock springs would be tight and not work well with Associated, but I have interchanged several of the parts (including spirngs) between Hot Bodies and Associated shocks.
SEF is offline
Old 06-13-2012, 06:19 PM
  #596
tc5 man's Avatar
Ok im getting confused with the RC8Tce manuel on the tuning . Well it says with the rear shocks mounted on the outside of the arms will give you less side bite but more predictble when the traction breaks sounds right on that . But less side bite than having the shock mounted in the inside of the rear arms how can that be
tc5 man is offline
Old 06-14-2012, 06:00 AM
  #597
i know that kyosho spring will fit on rc8.2 buggy and i think should be fit on kyosho spring on rc8te truggy maybe
taztal3 is offline
Old 06-14-2012, 06:39 AM
  #598
DaveW's Avatar
Sidebite is generated through chassis roll. Shocks out on the arm decreases chassis roll, and decreases side bite. Inside on the arm is the opposite.
Raising the inner rear camber link, or lowering the outside rear camber link increases camber gain and adds sidebite... but there is a balance between chassis roll generated through shock position and/or camber link position. You cant really use one to excessively compensate for the other...
DaveW is offline
Old 06-14-2012, 09:08 AM
  #599
anyone have try those rc8 .5deg toe bushing on truggy ?
taztal3 is offline
Old 06-14-2012, 09:18 AM
  #600
DaveW's Avatar
I did months ago in the B plate for some inboard toe in and/or out as an experiment. My setup now is so different from then, i wonder if i would like it better now...
DaveW is offline
