Team Associated RC8Te Thread >
Old 04-17-2012, 10:59 PM
  #556
Suspended
Trader Rating: 440 (99%+)
Will AE ever release a Factory Team RC8TE? I'm wanting a brushless rc8t but don't want to deal with buying a new nitro one and then buying the conversion. I would like an electric setup out of the box.
MattP is offline
Old 04-18-2012, 12:25 AM
  #557
DaveW's Avatar
It would be nice if they did... but not likely. I bought my 8Te used (like my 8B) and put on it what i wanted. As a matter of fact i think the only options i added were the aluminum big bores, AE CF shock towers, the awesome A,B,C,D plates, and the AL tube center braces. The rest was just replacing what was worn. Im not big on bling, im a function>form kinda guy.
Regardless tho... i got mine with an RX8 and the 2000kv T8 motor for $400. The buggy was a better deal with the MMM and 2200kv for $200... but it needs a lot more work than the truggy did.
DaveW is offline
Old 04-19-2012, 11:18 AM
  #558
DaveW's Avatar
Pic time. Im excited to try these...
DaveW is offline
Old 04-19-2012, 11:56 AM
  #559
DaveW's Avatar
General overview. Its still dirty from Saturdays laps...
Rear shock position...
Front shock position...
It looks like we might get rained out this weekend... but just in case... ill be adding the shorter hubs, and bronze springs to the current setup. Im also going to a smaller spur/up on pinion, and dropping timing on the motor. Hopefully i can drop some operating temp and still maintain throttle feel...
DaveW is offline
Old 04-19-2012, 12:47 PM
  #560
tc5 man's Avatar
Thanks for the pics man ! Man you have a small amount of rear shock preload your ride height must be low and the front end also. Does your track have big double jumps ? I know my preload on the rear shocks is more with the arms/axles leveled my my front shocks have a little less preload with the arms above level a bit. But i know you run heavyer shock oil than me so you can get away with lower ride height.
I notice you have the factory RC8T i have the RC8TCE Ed. With a Tekno v4 chassis and plastic chassis braces but im looking at getting some alum ones the chassis seems to flex more than the nitro RC8T chassis. Im going to try the same supension setup you have in the pic.
tc5 man is offline
Old 04-19-2012, 12:53 PM
  #561
tc5 man's Avatar
You will like the Narrow hubs on this truck it makes it feel like a Buggy kind of not like a typical Truggy handling.
tc5 man is offline
Old 04-19-2012, 02:24 PM
  #562
DaveW's Avatar
Thats what i was hoping for... i wanna get rid of a little bit of the 'truck' feel.
My shock preload will be less mostly because of the inner position on the arm. So ill have less preload and less droop (if measured via shock length anyways) than a setup using the outer positions on the arm.
My rideheight was 37mm front and 42mm rear... but i raised the rear a touch so its prolly closer to 43mm now. It feels decent with the swaybars im using.
We dont really have 'big' jumps... at least not by my definition. We have a quad or double-double (its faster to dub-dub it), and trip-singling it is askin for trouble. We also run counterclockwise... not the greatest pic...
One from this morning checking out how much damage the rain did. For this shot, im standing where the white truck is in the pic above...
This is typically what the surface looks like... when the sun goes down the moisture comes up and it gets NICEE...
My 8T had the black stamped steel hingepin mounts and shock towers, the plastic center braces, and the plastic steering plate with plastic shocks. I added everything you see there. Im not much on bling. Just whats durable and functional. I had to have the carbon towers tho... reminds me of the old B2/T2 days.
DaveW is offline
Old 04-19-2012, 07:26 PM
  #563
tc5 man's Avatar
Oh i see yea the jumps at the outdoor track i go to has bigger doubles than yours. Im going to try the setup you have in the pics but with the bronze front spring during a practice and see how i like it. Im really thinking about ditching the Alum shock towers and getting the Carbon towers to lose some weight for one my is a tank lol. The only thing i dont like is the lack of camber holes on the front Carbon tower.
tc5 man is offline
Old 04-19-2012, 08:20 PM
  #564
Suspended
Trader Rating: 2 (75%+)
tc5 man hey were can i get RC8T Truggy Carbon Fiber front and Rear Shock Tower and top one as well and do i need any think easl for that spur one do i need anythin easl can i just put it on
Zangetsu is offline
Old 04-19-2012, 09:11 PM
  #565
Trader Rating: 29 (100%+)
dave w - pm sent
taztal3 is offline
Old 04-19-2012, 09:25 PM
  #566
tc5 man's Avatar
You can get the Carbon towers anywhere the good thing is theres aftermarket Carbon towers that are cheaper. But you do have to use CA glue on the sides of the tower to prevent them from tearing apart.
The 2nd question i dint quite understand you ?
tc5 man is offline
Old 04-19-2012, 09:33 PM
  #567
Suspended
The spur gear I just unscrew it then replace it with a plastic one screw back on again is that right
Zangetsu is offline
Old 04-19-2012, 09:37 PM
  #568
tc5 man's Avatar
Oh ok yup thats all you do but if theres some rough edges on the inside of the spur gear lightly sand it and make sure to tighten the diff screws in a X" pattern and dont over tighten them !
tc5 man is offline
Old 04-20-2012, 11:12 PM
  #569
Whats your favorite body for the rc8t? I need a new one bad....
kroggs is offline
Old 04-20-2012, 11:23 PM
  #570
Suspended
Hey guys I am thinking going back to the normale rc8t ce Chassie and buy the new motor mount which they brought out with 8.2e I just don't like how closed pinion and spur sit too the esc and start lighting it up that way what yours guys think have yours try lighten the Chassie by piss off the Tekno v4 kit going back to normale try lighting that way
Zangetsu is offline
