Team Associated RC8Te Thread >
Old 02-28-2012, 09:13 PM
  #481
Trader Rating: 29 (100%+)
tc5 man -what about rc8.2e motor mount will fit on rc8t ?
taztal3 is offline
Old 02-28-2012, 09:45 PM
  #482
carrotcake's Avatar
Originally Posted by taztal3
if rc8t.2e truggy come out then i would buy one .
they scrapped the RC8t"e" ---- I dont' think they will come out with a Factory Team RC8.2Te ---- I have been hoping for a Factory Team RC8t"e" for more than 3 yrs now. I've my own "Factory Team / Upgrade version" for more than 3 yrs now --- though it runs solid, but would love to see a new RC8.2T"e" with some new features come out.
carrotcake is offline
Old 02-28-2012, 10:09 PM
  #483
tc5 man's Avatar
I would think it whould but im not sure.
The new lower wing mount from the RC8.2 fits also ive heard on here.
tc5 man is offline
Old 02-28-2012, 10:16 PM
  #484
carrotcake's Avatar
Default parts between RC8 and RC8T
just food for thought, way back I bought a bunch of Integy bling bling parts for my RC8Te. Steering rack, Caster blocks, Hubs. None of them fit, they're a little bit different in terms of positions and shape, but they do look very familiar. The angles are all wrong...at first I thought I did not tune my truck properly but after I put my stock parts back in everything seems to dial in again.
The parts were labelled for RC8...so I can't argue suppose to be compatible with RC8T....just took my own risk and wasted my money.
Or --- could be simply the Integy parts don't fit period.... anyway, I won't risk it if I was given a second chance to choose.
Old 02-29-2012, 09:34 AM
  #485
boudin4evr's Avatar
Trader Rating: 18 (100%+)
I don't see why it wouldn't fit
I have an elite mount on my truggy
and my 8.2e has the new mount.
same plate goes underneath them!
so i would say 99.99% yes
I would try it, but I have an elite mount on my truggy
the new AE mount is 1/2 the price of the elite, but elite mount is
very nice, Maifield uses them!
boudin4evr is offline
Old 03-01-2012, 11:43 PM
  #486
Just ordered my RX8/2000kv setup!!! I was going after the 1700 kv setup but got tired of waiting for it to be available. Going to run it on 4s!!! Now just to find a charger!!!
Anyone have a good starting point for the rx8 without the hotwire???
Thanks Kevin...
kroggs is offline
Old 03-02-2012, 12:05 AM
  #487
just bought a used mamba combo from surfingbird ..now im looking for batts.is 14.8v 5000mah 20/30c 4s batt good?and for those who have the same set up,do you guys use external BEC? IM running 3pk 2.4g radio
m0thertruckah1 is offline
Old 03-02-2012, 03:52 AM
  #488
JayRC66's Avatar
Questions?? ESC question?
Has anyone tried using the "Team Orion Vortex R8 Pro 1/8 Scale Brushless ESC (180A, 2-6S)"?
JayRC66 is offline
Old 03-02-2012, 03:59 AM
  #489
JayRC66's Avatar
Post My setup
I am converting my RC8B and RC8T to electric. I have the conversion kits. On my RC8T I am putting the Tekin RX8 with T8 2000KV. On the RC8B I am putting the Orion R8. Not sure what motor for the RC8B. Any suggestion and comments would be appreciated.
JayRC66 is offline
Old 03-02-2012, 05:28 PM
  #490
drew wit's Avatar
1950 orion or tekin 1900 is perfect
drew wit is offline
Old 03-06-2012, 07:06 PM
  #491
What pitch is the spur and pinion on these electric conversions??? And would a 46 or 50 spur be the hot ticket???
kroggs is offline
Old 03-06-2012, 07:20 PM
  #492
DaveW's Avatar
Are you racing or just playin around with it? Either way you are gonna have to take your runtime into consideration.
If you race for 10 minutes on a track, your gearing by temperature would be different than if you ran a full battery for 20 minutes out in the backyard. Odds are your motor would be a lot hotter after 20 minutes in the yard than at the end of a 10 minute track run.
If you use a 50/16 and adjust your speedo accordingly... and it isnt fast enough for your use... then you need a faster motor (higher kv). Temperature is your key ingredient here. You cant just add more gear (46/16 vs 50/16) to make the truggy faster if it overheats the motor/speedo/battery. Gearing adjustment is limited for each kv motor class.
DaveW is offline
Old 03-08-2012, 09:44 PM
  #493
Is there any other option to battery trays besides going to a Tekno kit? I want to run a 4s 5000mah and they are all to long unless I spend a bunch of money... Or what have you guys done to extend your trays?
Thanks.
kroggs is offline
Old 03-11-2012, 10:33 PM
  #494
DaveW's Avatar
WAKE UP PEOPLES. lol
Is everyone pretty much running a box stock setup? Has anyone tried any springs from a different chassis that fit with different rates?
DaveW is offline
Old 03-13-2012, 09:54 PM
  #495
tc5 man's Avatar
Yea i know this tread is dead um i never tired the diffrent rate of RC8T springs but i never heard of many that do to be honest you can try it though and report it back on here i want to know. I acutally used the stock springs that came on the RC8TCE with the stock shock pistons with 35w f and 35 R. That seems to work pretty good on the Associated conversion kit at least i tried 30w f and 30R. And it was ok not great dint jump the same or handle but i should of went to a softer spring or a diffrent piston.
tc5 man is offline
