Team Associated RC8Te Thread >
Old 01-16-2012, 07:41 PM
  #451
tc5 man's Avatar
Originally Posted by DaveW
Holy crap. 400oz? It says its .18 at 5v though. If i could get something closer to .10 i would be happy...
Heres the specs on the Hitec 7954sh servo.
And theres no need for a external BEC if you run a castle monster combo.
Size Category: Standard
Type: Digital
Torque: 333 oz @ 6V, 403 oz @ 7.4V
Speed: 0.15 sec/60 deg. @ 6V, 0.12 sec/60 deg. @ 7.4V
Bushing Or Bearing: Bearing
Bearing: Dual
Its $99.00
tc5 man is offline
Old 01-16-2012, 09:51 PM
  #452
DaveW's Avatar
Im using a Tekin RX8 with 2000kv motor. The servo seems fine without an external BEC... just doesnt seem to have any holding power.
DaveW is offline
Old 01-16-2012, 09:54 PM
  #453
tc5 man's Avatar
Yea its the servo your using than plus the savox servo you were using was marked as a high speed servo not ultra torque which truggys need.
tc5 man is offline
Old 01-17-2012, 04:11 PM
  #454
DaveW's Avatar
Just got finished shaking it down and the servo seems to do fairly well. I like the speed, and it throws the wheels lock to lock on the ground. Ill find out Saturday how it does on the jumps...
... oh and 4s is sick. I dunno who would want any less.
DaveW is offline
Old 01-17-2012, 04:22 PM
  #455
tc5 man's Avatar
But does the servo hold (strength ) when you let go the steering wheel thats the important thing.
Oh yea 4s lipos are crazy man on a truggy !
tc5 man is offline
Old 01-17-2012, 11:42 PM
  #456
DaveW's Avatar
In the grass at high speed it seems to lose steering (not to mention if i goose the throttle she will do a flip!), while trying to remain smooth and keep all four on the ground. You can see the wheels are bouncing around even though i have the wheel partially turned (like a long gradual high speed sweeper). Im not sure if its the servo, or the servo saver doing that.
I just rebuilt the entire truck so the servo saver works smoothly and is adjusted per the manual. My local track has considerably less bite than grass... so it might not be an issue.
I gotta say this RX8 running a close version of Randy Pike's setup is pretty effing amazing. Smooth and easy to modulate the corners... and OMG tons of TQ!!
I think i need better batteries... again... lol. These 2s 45c Trinity packs are puffing up a lil bit after only 3 runs. I made a custom Y harness and used Deans plugs and 12ga Wet Noodle. The speedo never got past 3 LEDs for temp and the motor was warm but not uncomfortable to touch after i dumped the packs. Took about 12 minutes.
DaveW is offline
Old 01-27-2012, 12:06 AM
  #457
kneedeeppow's Avatar
hey guys
anyone have some suggestions for shock oil/spring combos? got a pretty bumpy uneven track surface with good amount of twisty stuff
cheers
kneedeeppow is offline
Old 01-27-2012, 12:49 AM
  #458
Suspended
Trader Rating: 2 (75%+)
hello all could you tell me what do you think of this setup or could tell me something better
my setup will be
rc8t ce. with team ae conversion kit
2x Turnigy nano-tech 6600mah 2S2P 65~130C Hardcase Lipo Pack
to make up to 14.8v
brushless combo.XERUN Sensored 4274SD 2200KV
servo.savox 1258gt servo
or could you give me a set u better or not
Zangetsu is offline
Old 01-27-2012, 06:01 PM
  #459
Suspended
What. Guys think
Zangetsu is offline
Old 01-29-2012, 02:00 PM
  #460
Led Finger's Avatar
Default pics
pics of my rc8te
Attached Thumbnails Team Associated RC8Te Thread-img_0498.jpg   Team Associated RC8Te Thread-img_0496.jpg
Led Finger is offline
Old 02-08-2012, 09:25 PM
  #461
Hey Fellas just bought a used rc8e it is the factory team edition with a gGrid motor mount, and have only basic knowledge of the lipo system...
Is there any sticky threads or places to learn about the brushless and lipo systems?
Suggest some setups for me if you will. I will just be fun running for the most part. My brother inlaw has a track to play on and a dirt bike track that is mainly sand to have fun...
Looking for The KV info and what cells... I want longer run times and some speed but dont need it to be blistering fast either... At the moment the cheaper the better...
kroggs is offline
Old 02-08-2012, 10:05 PM
  #462
DaveW's Avatar
Originally Posted by kneedeeppow
hey guys
cheers
This will largely depend on the grip available and your diff oils. Im running 7/10/3 and its got a little bit of a push coming into a haripin type corner.
Ive settled on kit 6 hole pistons front and rear and black spring front with 35wt and bronze spring rear 35wt. Kit shock positions. Its decent on throttle and keeps the rear from squatting so much allowing me a little more on power steering.
My 257TG Savox servo is doing great for steering duties so far...
DaveW is offline
Old 02-09-2012, 04:11 AM
  #463
Suspended
Hey guys I am look at getting the tenshock 1/8 6 pole 1850kv would that run on the 6800 70c 4s lipos or should I get the 2200kv one it's running on out side 1/8 track the car is a rc8t ce tekno v4
Zangetsu is offline
Old 02-11-2012, 06:38 PM
  #464
DaveW's Avatar
Man this truck is fun!
2 degrees rear toe, 2 degrees rear squat
-1.5 degrees front camber, -2 degrees rear camber (upper hingepin hole on rear hub, outer link hole on rear hub, middle hole rear tower)
black front, silver rear springs (or silver front, bronze rear if the track has the grip)
35wt oil front
30wt oil rear
slightly below arms level front
bones level rear
still 7/10/3 but gonna put a diff together with 5 in the front to compare
I know there is a lot more to a setup than this but these are the big things i changed today (over the kit setup). The front drops its nose like a 2wd buggy over jumps by barely lifting the throttle... turns in beautifully off power (but i think the 5k diff oil will be perfect) and plants but doesnt excessively squat when you roll on the throttle from one corner to the next. Its really easy to maintain corner speed and a smooth radiused corner... and compound jumps are cake.
Maybe its me being used to 1/10... but this thing has gobs of traction (as long as there isnt any fluff... thats tire/insert choice too, i had blue IBeams with blue molded inserts today), and is EASY to drive. 20 minutes on the wheel feels like 5 minutes in 1/10 2wd buggy.
Tekin RX8/T8 2000kv and 4s on smallest e spur with 16t pinion.
DaveW is offline
Old 02-19-2012, 09:44 PM
  #465
For those running the AE conversion are you cutting the battery tray to allow the bigger packs to fit and relocating the speed controller? I was thinking of doing the low KV high voltage setup and need more tray space if I'm measuring right...
kroggs is offline
