Team Associated RC8Te Thread >
Old 06-29-2011, 10:02 PM
  #361
Dentman's Avatar
Good job,, I need some diff and shock help. I'm running 10k20k7k 45shock wgt all four shocks.... I feel the ass ends spinds around on corners.. I wouild like to corner on the gas and be straigth. also hammer down a straight and it go straight... Got ideas???????
Dentman is offline
Old 06-29-2011, 10:15 PM
  #362
tc5 man's Avatar
i would use 35w oil on the front and rear shocks with the stock pistons so you can get more grip aroud the corners .
i run that and its planted .
dam 10k in the front diff thats heavy man !
tc5 man is offline
Old 06-30-2011, 04:59 AM
  #363
jetbill007's Avatar
Trader Rating: 20 (100%+)
Thunder Power G6 4S 5300 Lipos Newly used For Sale.
http://www.rctech.net/forum/r-c-item...v-5300mah.html
jetbill007 is offline
Old 07-02-2011, 02:13 AM
  #364
Trader Rating: 41 (100%+)
Default Rc8te gearing and setup ?s
Hey fellas, I've got a rc8te with a rx8/1700kv combo, running 4s, 50t spur, what pinion should I use?
TheRevolution is offline
Old 07-02-2011, 03:23 AM
  #365
kneedeeppow's Avatar
14-18t would be a range you could try. gear to temp,if it gets warm/hot then gear accordingly.
here is my rig in action
http://youtu.be/qvKE7d7hhww
kneedeeppow is offline
Old 07-04-2011, 02:22 AM
  #366
Diggity's Avatar
Trader Rating: 33 (100%+)
Default Rear Chassis Brace Stiffiner Inserts
Team Associated RC8B/RC8BE and RC8T/RC8TE - New 2.5mm rear chassis brace stiffiner inserts. Similar to the ones used by Maifield and Cavaleiri.
Checkout the website for more info.
Diggity is offline
Old 07-06-2011, 09:09 PM
  #367
longbill76's Avatar
RC8/T, D8/T/Vorza, MBX6 & 808 motor mounts are now back in stock... ready for purchase at www.Elitercd.com
longbill76 is offline
Old 07-09-2011, 09:29 PM
  #368
tc5 man's Avatar
well i raced today and tested out" 7k" in the center its ok but i like the hard torque that "10k" gives you and coming out of the turns also.
the "7k" in the center does give you a smoother feeling, from take offs and coming out of turns but it does feel kind of soft .
but it does take away the front brake feeling.
i might go back to 10k in the center not sure yet.
tc5 man is offline
Old 07-09-2011, 09:33 PM
  #369
Dentman's Avatar
the 7k in the center does give you a smoother feeling from take offs and coming out of turns .
I think 7 front 10 center 5 rear is gonna be the winner for me.. I gotta change my front and I"m good.. I won my local race with 10\10\5 but is had just a touch of push on power in the corners.. most likely from the 10 up front
Dentman is offline
Old 07-09-2011, 09:37 PM
  #370
tc5 man's Avatar
yea i see what you mean the 10k in the center just has a better feel to me.
im still running 7k f , 5k r .
yea i kinda like a push and i kinda dont lol.
tc5 man is offline
Old 07-09-2011, 09:51 PM
  #371
tc5 man's Avatar
maybe it was just the way the track was today it was bumpy and a lot of loose soil/loomy dirt from the rain .
tc5 man is offline
Old 07-10-2011, 12:22 PM
  #372
tc5 man's Avatar
i checked over my truck today and notice for the 2nd time one of my rear chamber link is bent bad enough to cause a bind .
im starting to think its because im useing titanuim rear turnbuckles you know strong vs weak . i do know the camber links do flex, and i have tried to straighten them out but i dont want to mess up the metal ball cups though its annoying
when i was using the steel rear turnbuckles, the plastic camber links never got bent but than again i was running this truck as a nitro so it was lighter.
i have heard you can use the rear plastic camber links off the tamiya 1/8 truggy ?
Tamiya Rod End/Body Mount Set (E Parts)
[TAM9004240]
tc5 man is offline
Old 07-17-2011, 07:52 PM
  #373
tc5 man's Avatar
well i tryed out the "5k in the rear again its ok, but the only thing i dont like is when i let of the throttle into a turn and than hit the gas its wants to go straight and not rotate as much .
Kind of like a point and shoot somewhat kind of driving.
I like the "7k" in the center diff though.
the track i was at today was dry and dusty and somewhat rough.
so im buying a extra gear set and try 3k in the rear.
tc5 man is offline
Old 07-17-2011, 08:06 PM
  #374
Trader Rating: 64 (100%+)
I have 5 front 10 center and 3 in rear and i an turning faster lap times then the buggy guys i love this set up on loose tracks
nofinger rc8be is offline
Old 07-17-2011, 08:11 PM
  #375
tc5 man's Avatar
yea i did use "10k in the center, but it tends to catch me off guard sometimes coming out of turns because it throttles out of turns quickly.
but maybe using "5k in the front like your using makes it better maybe.
im just going to try one thing at a time now and use "3k" in the rear.
whats the 5k do on a loose track ?
tc5 man is offline
