Team Associated RC8Te Thread
#227
For you guys that are running 2 packs in the back, are you starting with an E, or T chassis?
I know that someone mentioned there was alot more room on the T chassis, but are you running a conversion kit, or did you just bolt a motor mount to the chassis. Forgive me if this is a dumb question, as the only conversion kit I know is the Tekno, which changes the whole chassis.
#228
#229
Is the battery area on the chassis wide enough to hold 2 5000mah LiPos.
#231
Hello everyone, I just finished my RC8Te build and I have a question. I ended up with some crazy postive camber. Anyone else expirience this or did I just screw up somewhere? Just thought i would ask before I go adjusting everything or hacking off some of the turnbuckle lengths.
#232
what r they 2 2s's of 2 4s's?
#233
The front, you have to move the upper arm link from the inner most hole on the hub to the outer one. I think it was with the case with early RC8Te kits. Associated just doesn't get it right in their manuals the first time around. Geometry was all off on my early SC10 build too.
#234
I was able to mount my ESC and RX on the outside of the steering servo. Made a custom carbon fiber plate and then mounted the electronics on it. All the wiring is under the tray. I will post some pics when I get back home from vacation next week. Last 2 things I need to do are run my wires to the battery packs and wire up the motor.
Chi
#235
The rears should be no issues.
#236
Thanks 529 you answered my question. What are most people running 2S or 4S
#238
Thanks mad
#240
Finally got it converted to a 2 pack setup. Wanted to go with std. battery trays w/ straps, by my LHS wanted $30 each for them & I seen these old RC10 battery cups hanging on the wall for $5 each. It works great for std. size 2S packs, but I was hoping to run my 2 Venom 8000mah packs for the mains & they are too tall for these battery cups. Oh well, maybe I can come up with a cheap mod before I have to brake down & spend the $60 on the Tekno trays.
