Team Associated RC8Te Thread >
Old 05-04-2010, 12:29 PM
  #211
no when u do a 2 2s in series setup u come off from the negative on the first battery and u dont have to tap into the balance tap. so on a 4s what ur doing is tapping off of the negative on the 2nd battery in the series
madmikegxp is offline
Old 05-04-2010, 01:37 PM
  #212
Trader Rating: 80 (100%+)
So are you saying that a pre-built 4s is actually 2 2s so is really equally drawing from each of the cells in the "2s"? Then when i charge a 4s aren't you gonna have a balance in difference still?
Chirag
cpatel529 is offline
Old 05-04-2010, 01:59 PM
  #213
yeah thats right. just keep an eye out. if u have a battery voltage tester to see each battery and see if there is any drop of voltage in any of the cells
Old 05-04-2010, 03:45 PM
  #214
tower hobbies is selling it http://www3.towerhobbies.com/cgi-bin...?&I=LXXLY7&P=0
and with the bec make sure u only have 7.4v going to it or it will fry, i did that with mine. u can tap off from ur balancing tap
his advice is spot on but you can get that part more cheaply here
http://www.impaktrc.com/product_info...oducts_id=4324
bohdi is offline
Old 05-06-2010, 10:20 AM
  #215
Well I finally received a good portion of my parts and electronics to continue my RC8T-E conversion.
Need to figure out where to mount the ESC and receiver. I think that I am gonna make a carbon fiber platform next to the steering servo that runs around to the center diff area and mount the ESC and receiver there. I want to keep them as low as possible and keep them on the servo side to add better left/right balance.
Thoughts/Comments/Suggestions?
Attached Thumbnails Team Associated RC8Te Thread-rc8t-001.jpg   Team Associated RC8Te Thread-rc8t-002.jpg   Team Associated RC8Te Thread-rc8t-003.jpg   Team Associated RC8Te Thread-rc8t-007.jpg   Team Associated RC8Te Thread-rc8t-009.jpg
Old 05-06-2010, 10:33 AM
  #216
Trader Rating: 17 (95%+)
That looks really good, I like the balance with the batteries. I know I am running a MMM in my RC8B conversion and from your pictures there is no way my ESC would fit next to the servo. But if you can make it work with your ESC thats sweet, I will look forward to seeing your pictures of it completed.
Oreellyfool is offline
Old 05-06-2010, 10:44 AM
  #217
Thanks! Im running the LRP SPX8. It is the same size as the LRP TC Spec.
Chi
Old 05-06-2010, 10:49 AM
  #218
Chi
so why not use the AE recvr/servo box?
bohdi is offline
Old 05-06-2010, 10:51 AM
  #219
I was looking into that as well. Is there enough room in that box to mount the ESC and the receiver? I would probably modify the cover as necessary.
Anyone have any dimensions of the inside of that box?
Old 05-06-2010, 11:20 AM
  #220
hlb14's Avatar
Trader Rating: 28 (100%+)
a spx8 might fit in there with a micro rx and a modified cover
hlb14 is offline
Old 05-06-2010, 04:35 PM
  #221
What kind of connectors are people running for the battery/ESC connection for 4s? I currently have Traxxas connectors on my batteries but I want to swap them to the ultra deans plugs since they are smaller and easier to solder multiple wires to the leads. Will the Deans plugs get too hot?
Any suggestions?
Old 05-06-2010, 04:50 PM
  #222
JSR
Trader Rating: 18 (100%+)
Deans will be fine. I run Deans on my truggy on 4s which is a lot heavier than the current breed of truggies.
JSR is offline
Old 05-09-2010, 06:02 PM
  #223
prdmetalworks's Avatar
I'm trying to get into electric truggies because this class has gotten huge at my local track since we went outdoors. Problem is, I'm on a budget (spend too much on my 10th scale), so I'm looking to get a used one. I really want a Factory team truck that has been converted & I finally found one on ebay.
I am currently the high bidder, but I am having second thoughts about how high I want to go? I really wanted to go with a Tekin motor & speed control, running 6S with a 1350, but this truck includes a Mamba Monster with a Castle 2200kv. There are a few guys at my local track that run 2000kv on 4S, but hey seem to have alot more heat / run time issues than the lower kv / 6S setups?
So I'm wondering - is a 2200kv too much? Seems like a buggy motor to me, but I'm pretty new to 8th scale stuff? If I could get away running this motor until I can get what I want, what pack would be a good match?
Oh yea, I need to be able to make a 15 minute main
prdmetalworks is offline
Old 05-09-2010, 06:35 PM
  #224
Nogas's Avatar
Any suggestions?
I ran deans for a while but got sick of them popping apart mid race and then sometimes they are difficult to pull apart when you want them to come apart??? I use EC5's now.
We are making 15 min mains with 2200kv MMM's in E revo's with 2 x 5000mah 30c packs , so i'd imagine you should make it with a well set up truggy, most people seem to use a bit lower KV motor in truggys though.
Maybe go for a slighty bigger (6000mah) 4s pack to be safe. You dont want to dump last corner
Nogas is offline
Old 05-09-2010, 06:55 PM
  #225
Are you guys running 2 4S 5000 packs, or 2 2S 5000 packs?
As Long as I'm talking batery packs - would 2 2S 6000 packs be equal to 1 4S 6000, or does one have an advantage over the other?
