Team Associated RC8Te Thread >
Old 04-11-2010, 10:15 PM
  #166
killermmn's Avatar
yes you can use the steel spur gear from rc8t!!
killermmn is offline
Old 04-13-2010, 02:01 PM
  #167
Cmjomaha's Avatar
I am getting ready to build my RC8Te and I am placing my order for a few last second addons....most from spending too much time in this thread. Anyways I am looking for a 48t spur and I can't seem to find one. I run the RR 48t wide in my losi 8T, but it seems that spur is only for the losi 8. So anyone know of a place to look for a 48t or why the RR one is for the 8 only. Does it have to do with chassis clearence?? Thanks ahead of time for any help...
Cmjomaha is offline
Old 04-13-2010, 02:09 PM
  #168
found it here but out of stock for the moment http://www.horizonhobby.com/Products...rodID=ASC89520 or here http://www3.towerhobbies.com/cgi-bin...?&I=LXXMA0&P=0
madmikegxp is offline
Old 04-17-2010, 12:05 PM
  #169
Anyone looking to upgrade the plastic shocks on your RC8TE, I've just posted a new set of 16mm big bores in the for sale section.
http://www.rctech.net/forum/r-c-item...s-springs.html
g26er is offline
Old 04-18-2010, 09:08 AM
  #170
NorthCentral RC's Avatar
What batteries do you guys run in your 8te? I am looking for some suggestions. I just built a new one but I am finding that the battery holder is to short for most packs. I am looking for something with enough juice to run a 20 to 30 minute main and it has to be 4s preferably hard case. Any help is appreciated! Thanks!
NorthCentral RC is offline
Old 04-18-2010, 03:03 PM
  #171
R/C Tech Elite Member
TheCore's Avatar
Trader Rating: 45 (100%+)
i have 4s 5800 zippys (softcase) and 4s 5000 turnigys (softcase) that are a little snug but fit. you just need to dremel the tray out a little bit for the wires to exit clean. they have 8awg wire on 'em so be prepared to solder end of with a pretty big iron.
TheCore is offline
Old 04-18-2010, 03:23 PM
  #172
prettyboy's Avatar
Trader Rating: 59 (100%+)
You need to find Lipo's that are (L=141mm x W=48.5mm x H=51.7mm) I found that the Max-Amp & Thunder Power Lipo both are hard case fit like a glove with out having to do any cutting of the batt tray. I run the Max-Amp 4s 6500 hard case it fits perfect and it handles the power draw great and I can run a 25-30 min main with no problem..But this is just my 2 cents..
Rob
prettyboy is offline
Old 04-18-2010, 03:34 PM
  #173
prettyboy's Avatar
Originally Posted by madmikegxp
Take a look at Associtated Parts Warehouse . Here is the links for it..
http://www.losipartshouse.com/servle...ic-Spur/Detail
Old 04-25-2010, 12:38 PM
  #174
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Assembling my RC8Te....does anyone have trouble putting in the wheel hex pin for the rear? Seems once I put in the plastic bearing shield and slide the axle through the hub, I can't get the pin in after attaching the wheel hex. Part fitment issue? Or just run without the plastic ring?
Dan is offline
Old 04-25-2010, 03:38 PM
  #175
TheCore's Avatar
i had no problem that i recall with mine. are you possibly getting hung up on one of your bearings sliding the axle through ? make sure your bearings are in all the way and straight.
TheCore is offline
Old 04-25-2010, 03:40 PM
  #176
Dan,
I assume you are talking about step 20 in the install manual. I didn't have a problem here. Make sure that the bearings are all seated evenly. Everything should line up.
ml8163 is offline
Old 04-25-2010, 07:14 PM
  #177
Dan
Dan's Avatar
Thanks guys, turns out I had the rubber boot from the outside of the axle, instead of within the groove. It allowed it to be just 1mm off for the axle pin. Doh.
Dan is offline
Old 04-26-2010, 05:09 PM
  #178
neospirit's Avatar
Trader Rating: 48 (100%+)
Default Converting SC8e
What will I need to convert SC8e to RC8Te? Can I just put the RC8Te body, wheels and tires on the SC8e?
neospirit is offline
Old 04-26-2010, 07:54 PM
  #179
Dan
Dan's Avatar
Think you need to change at least the arms, CVD's, and upper/steering links.
Dan is offline
Old 04-26-2010, 09:41 PM
  #180
A pair of the following fit the associated battery box perfectly with the stock padding on the ends of the box but no padding on the sides. You will not get 30 minutes out of them though. Probably not even 20 minutes in a race. Typically when running 4s the 15 minute mark is all you can shoot for.
http://www.hobbycity.com/hobbyking/s...dproduct=10277
kcobra is offline
