Team Associated RC8Te Thread >
Old 04-10-2010, 03:44 AM
  #151
adrictan's Avatar
My RC8T CE kit is coming on Mon so I'll need some advice frm you guys.
If I'm not wrong, the kit will have composite chassis braces.
Should I order Aluminum ones?
The problem is: It seems like there 2 types.
Front:
Associated #89378 OR Associated #89320
Rear:
Associated #89379 OR Associated #89321
Should I get it and which ones to get?
adrictan is offline
Old 04-10-2010, 07:58 AM
  #152
R/C Tech Elite Member
TheCore's Avatar
Trader Rating: 45 (100%+)
i put the solid aluminum ones on my truggy and the other ones on my wife's buggy.
i like 'em both as well, i figured the more rigid ones in the truggy and the plastic ends in the buggy for a bit more flex.
TheCore is offline
Old 04-10-2010, 11:12 AM
  #153
Front:
Rear:
These are the ones you want for the braces.
89378
89379
I would also recommend upgrading the suspension plates. For that, your going to want these.
89460 - Team Associated Suspension A-plate
89461 - Team Associated Suspension B-plate w/Pins
89462 - Team Associated Suspension C-plate
89463 - Team Associated Suspension D-plate w/Pins
ml8163 is offline
Old 04-10-2010, 09:31 PM
  #154
adrictan's Avatar
Can I check why there is a need to change to these suspension plates? Anything wrong with the ones tht come along?
BTW, does this come in the kit?
# 89380
adrictan is offline
Old 04-10-2010, 09:52 PM
  #155
TheCore's Avatar
# 89380
there's nothing "wrong" with the stock ones, the blue a, b, c & d plates are just stronger and allow for more tune-ability. becareful tho the blue is like a drug, and before ya know it you double the price of your ride just in blue upgrades.
wow, those are back in stock... mmm.. yummy blue aluminum
and no THOSE particular ones aren't included in the kit.
keep an eye out on ebay for the championship upgrades, the dismantlers spit out parts pretty regularly.
TheCore is offline
Old 04-10-2010, 10:41 PM
  #156
adrictan's Avatar
Ok. I'll think abt it. Thanks.
adrictan is offline
Old 04-11-2010, 09:24 AM
  #157
killermmn's Avatar
next thing i will put in my rc8t is the rear and front hub in alu and the new body!!
killermmn is offline
Old 04-11-2010, 10:12 AM
  #158
adrictan's Avatar
Sorry but can I check
if the screws provided are Metric or in MM?
adrictan is offline
Old 04-11-2010, 10:59 AM
  #159
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
Ain't mm a metric measurement?? The screws are metric on the RC8T
OfnaJoe is offline
Old 04-11-2010, 11:34 AM
  #160
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
My RC8Te is coming in soon. So all the hardware on it is metric for sure?
I hope this isn't a standard and metric mix like my old Losi 8ight RTR was. Drove me nuts!
Dan is offline
Old 04-11-2010, 12:24 PM
  #161
IMO the design of the FT suspension plates that hold the hinge pins is far superior in durability. The stock plate uses a screw as a stop for the hole the the hinge pin goes into. I think that the flaw with this design is when there is an impact, since so little of the hinge pin is actually inside the hole of the plate that is only a few milimeters thick, the force of the impact can allow the hinge pin to pop loose. I have first hand experience with this unfortunately. The blue is nice though...
But with the FT suspension plate, the B plate uses a bushing like the A plate and allows much more of the hinge pin to actually seat inside the plate. I ran this thing pretty hard all week end with out any problems, including a couple of jumps that involved at least a 10 cart wheel landing!
ml8163 is offline
Old 04-11-2010, 12:28 PM
  #162
killermmn's Avatar
metric screw and nut!!
Old 04-11-2010, 06:58 PM
  #163
Dan
Dan's Avatar
Does the RC8Te use 0 or 1/2 offset wheels? Or what does it come stock with?
Dan is offline
Old 04-11-2010, 07:04 PM
  #164
It uses 0 offset wheels. I have some 1/2 offset for mine that I like.
Hoodala is offline
Old 04-11-2010, 08:48 PM
  #165
Anybody know if I can use the Team Associated Steel Spur Gear instead of the plastic one which came with the RC8Te kit?
I just stripped the plastic spur. I understand that I would have to go with a hardened steel pinion. I was thinking of the Robinson Racing 5mm Bore Extra Hard Steel Mod 1 Pinion Gear (19T).
ml8163 is offline
