Team Associated RC8Te Thread >
Old 04-01-2010, 08:35 PM
  #136
prettyboy's Avatar
Trader Rating: 59 (100%+)
Originally Posted by OfnaJoe
Dang, just got the email back from Lundsford, $73 for turnbuckles
I found a set of RC8T's on ebay for $44, think I will get them and just buy the 90mm steering turnbuckles separate.
Hey Joe order them from A-Main hobbies here is a link to them. When you get them take the 2 steering turnbuckles out and call Lunford and tell them you will be mailing them to them for exchange for the 90mm and it will not cost you a dime but the shipping. Thats what I did and they had them to me in a week after I shiped them back..
http://www.amainhobbies.com/product_...rnbuckle-Kit-7
Let me know how you make out..
Rob
prettyboy is offline
Old 04-03-2010, 03:51 PM
  #137
Dan
Dan's Avatar
Trader Rating: 74 (100%+)
Anyone running the Tekno conversion?? I want to run the long shank pinions but do I need the adaptor plate too to go with the V3 kit?
Dan is offline
Old 04-03-2010, 06:11 PM
  #138
JSR
Trader Rating: 18 (100%+)
If you use the complete Tekno kit, you don't need any adapter plates (I assume you're referring to the center diff spacer?). Regardless, the Tekno kit comes complete.
If you, or anyone else, is interested, I have a 16T and 18T Tekno long shank pinions for sale. The 18T is brand new and the 16T has 3 runs. I no longer have a Tekno conversion, so don't really need the pinions.
I also have a brand new Tekno 42mm motor mount for sale with a fan that bolts right on if you want that too. PM me if interested.
JSR is offline
Old 04-03-2010, 09:33 PM
  #139
Dan
Dan's Avatar
Hmm...well, I have the V3 complete kit coming in too, but their site says if I use their long shank pinion, then I need the motor plate spacers. I ordered them anyways, just hope I didn't waste $10. I ordered a 12T pinion. I'll be running a 2650kv motor on 4S (I know, I know.... but its what I have now and I'll pay close attention to temps.)
Anyways, does anyone have any setup sheets from the pro-drivers? I'm really curious what everyone is running for diff oil and shock oil setup.
Dan is offline
Old 04-04-2010, 04:16 AM
  #140
Hi guys,
I have question regarding piniong gear for RC8Te. I want to buy new pinions, but I'm a bit confused with Mod and Pitch. For what do I need to care, Mod only?
E.g. will this pinion work:
Robinson Racing 5mm Bore Extra Hard Steel Mod 1 Pinion Gear (15T)[RRP1215]
Extra Hard Steel 5m/m Bore (1.0 module) Brushless Motor Pinions. One 4x4 m/m set screw included. These pinions mate with most 1/8 scale nitro spur gears.
I expect I need Mod 1 pinion, but not sure about Pitch (if I need to care about it at all). Thank you.
I'm using it with Tekin RX8 combo.
Biermann is offline
Old 04-04-2010, 05:41 AM
  #141
adrictan's Avatar
Originally Posted by Biermann
Hi guys,
Mod 1 pinions have no pitch. U're good to go with the one you indicated.
adrictan is offline
Old 04-04-2010, 11:27 AM
  #142
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
Default Xtreme Racing CF Shock towers ?????
Anybody using the Xtreme Racing carbon fiber shock towers? If so how did you mount the front body mounts? A pic would be nice too!!
Thanks Joe
OfnaJoe is offline
Old 04-04-2010, 11:28 AM
  #143
Trader Rating: 80 (100%+)
Just got my RC8TE! Now comes the fun parts. ESC and Motor. I think I am gonna go Speed Passion Citrix.
Chi
cpatel529 is offline
Old 04-04-2010, 11:30 AM
  #144
prettyboy's Avatar
Hi guys,
Just my 2 cents but take a look at the Associated 8th scale pinions. They work great thats all I use I have 14-16 tooth and that covers just about any size track you my come acrossed.
Old 04-04-2010, 11:38 AM
  #145
prettyboy's Avatar
I have yet to come acrossed any Team set ups for the RC8Te.
Here is what Iam running and works realy good for my driving style. Just remember set up is just 30% and drivers skills is 70% of the trucks performance..
Over all set up= Box stock set up after building (with small tweeks)
Front diff oil= 7000
Center diff oil=10000
Rear diff oil=5000
Shock oil all around 35wt
Rear camber 0 deg with upper camber link in the most inner hole on the rear hubs and center hole on the shock tower camber mount location
Hope this help with a starting set up..
Rob
Old 04-04-2010, 11:43 AM
  #146
prettyboy's Avatar
Thanks Joe
They mount the same way as if you were mounting them on the stock shock tower..
Old 04-04-2010, 12:37 PM
  #147
OfnaJoe's Avatar
That's what I thought, he sent the wrong tower
OfnaJoe is offline
Old 04-06-2010, 07:20 AM
  #148
hey guys just got mine yesterday and allmost done putting everything together. have to finish up installing the electronics, glueing tires, painting the body, and finally testing. im useing the lrp spx8 and vector 2500 kv, hitec servo, m11 with spektrum setup for the radio. cant wait to run it
madmikegxp is offline
Old 04-06-2010, 09:39 AM
  #149
Default Hex pin came out, why?
Has anyone had a problem with loosing the hex pin that holds the wheel hex on? The hex pin is held in place by a clip and set screw. The clip is in place and the gap on the clip was turned away from the pin hole. So, I don't know how the pin came out?
ml8163 is offline
Old 04-06-2010, 01:51 PM
  #150
R/C Tech Elite Member
TheCore's Avatar
Trader Rating: 45 (100%+)
*queue twilight zone music*
TheCore is offline
