Old 03-03-2009, 07:10 AM   #1
Trader Rating: 21 (100%+)
Default thrust bearing.....purpose??
what does a thrust bearing actually do in a diff. Do you need it? I've always wondered. Can you get away with using the washers without the balls?
fastbynature is offline   Reply With Quote
Old 03-03-2009, 07:13 AM   #2
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
Yes the thrust bearing is very necesarry.Without it in a diff of current designs your diff would loosen/tighten depending on which way you turned your car.
*Vandal 4wd Late model*XXX-T sprinter*Micro scale specialties 1/24 'rock monster' crawler*MSS Micro-Rail*MSS Micro-Funny*MSS Micro-Outlaw*
2wdMod is offline   Reply With Quote
Old 03-03-2009, 10:34 AM   #3
Tubaboy's Avatar
It also removes side pressure from bearings that fit inside the diff gear, allowing them to last longer.
www.wyomingrc.com | www.wyomingmodelerspark.com
Tubaboy is offline   Reply With Quote
Old 03-03-2009, 10:56 AM   #4
B-FAST R/C's Avatar
The head of the diff screw would want to spin with the left outdrive, the thrust bearing prevents that from happening. And since the nut does spin with the right outdrive if no thrust bearing were in place the diff would either loosen or over tighten as stated above.
If you allow the thrust bearing to deteriorate far enough this will happen as the bearing begins to seize.
www.bfastrc.com *** Feel The Diff!! ***
arcshobbies mcculloughsrcracing
B-FAST R/C is offline   Reply With Quote
Rc10ntc3 Taz_S Nitro On-Road 9437 05-28-2017 09:13 PM
1/10th pan car Taz_S Oval, Larger Scales and More 16138 09-25-2014 10:03 AM
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 08:57 PM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
1/12 Diff Question Takt Electric On-Road 23 12-09-2004 02:26 PM
Barracuda from Alex racing rcruv Electric On-Road 5110 02-27-2004 03:01 PM
