MBX5R Conversion Questions >
Old 03-02-2009, 09:55 AM
zfmrchnt's Avatar
Trader Rating: 34 (97%+)
Default MBX5R Conversion Questions
i have a couple of questions regarding converting my mbx5r to brushless.
what conversion kit worked best for you?
what motor esc combo do like?
all i can have are 3s unless i upgrade my charger,
will this be fine or what about running in series 6s,
can this be done in saddle pack style or is there not room for two batteries.
what about a koyosho center diff? or replacement diff?
any other advise you can pass alone would be appreciated.
thanks in advance
zfmrchnt is offline
Old 03-02-2009, 10:00 AM
zfmrchnt's Avatar
which monster combo would work better with 3s or 6s setups,
Neu-Castle 2650 KV
Neu-Castle 2200 KV
zfmrchnt is offline
Old 03-02-2009, 10:05 AM
Tech Legend
Cain's Avatar
Trader Rating: 253 (100%+)
thanks in advance
I would say for your situation, probably give the Caster Fusion upgrade package a look. This conversion should work on the MBX5R, I got to see one go recently and it worked quite well. It uses dual lipo 1/10 scale pack setup. I was thinking of trying it with 2 3S packs to run 6S in series with a low KV motor . You will probably need the caster mudguards.
http://www.casterracingusa.com/produ...6&cat=0&page=1
I wouldn't recommend 3S pack alone in a conversion. Guys tried this, and it can be done, but you need REALLY high end pack, with a high KV motor, and you are just putting more strain on the electronics and will most likely puff a pack.
Cain is offline
Old 03-02-2009, 10:11 AM
Tech Legend
Cain's Avatar
Neu-Castle 2650 KV
Neu-Castle 2200 KV
For 3S, again, I wouldn't recommend, but you could do the 2650Kv. You would want to use the following to determine gearing, which is about 40mph for race speeds:
http://scriptasylum.com/rc_speed/_top_speed.html
Again, I would not do this without a really high end pack if I had to. And by that I would want it easily over 180 amps continous rating as I have heard from others who have used quality cells (6000mah 25C packs) that they puffed them when using a 3S setup with a high KV motor.
If you go 6S, you would want something in the KV range of about 1400Kv.
Cain is offline
Old 03-02-2009, 10:38 AM
zfmrchnt's Avatar
can i run the current center diff?
i have heard of people swapping that out, not sure why?
zfmrchnt is offline
Old 03-02-2009, 11:03 AM
Tech Legend
Cain's Avatar
yes. mainly swapping the center diff was to use a plastic kyosho spur gear. My MBX5 came with this already done, the guy used a hot bodies diff. At the time, pinions were not hard enough to not get chewed up. They have come ALONG way.
Cain is offline
