Old 03-01-2009, 10:16 PM   #1
Default Losi Speed T off road?
First of all the website is great!
I am back into RC after an 18 year break and pick up a Slash and really like how tough it is wow can a slash take a beating.
Now I am want a brushless 1/10 scale stadium truck and thinking of converting a Losi Speed T to off road. Any one on here convert a Speed T?
bolt on the XXX-T shock towers and new shocks?
The HPI Firestorm Flux looks great but I think the 2.4 radio on the Speed T would be great.
Your comments are appreciated.
BMXRDAD
BMXRDAD is offline   Reply With Quote
Old 03-01-2009, 10:23 PM   #2
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to y2kgtp Send a message via Yahoo to y2kgtp
BMXRDAD
Sure....I'm planning on doing just that myself. Got some tires to match the local track, and pulled out the Plastic Spool rings for a diff kit from http://www.bfastrc.com/
I'm not even worried about the slightly shorter shocks or the more raked shock towers......
Of course my drivetrain is all moved around as I could not leave it alone, but that is a different story.....
"Yes my car is technically illegal, but still its either just as fast or slower than any other car on the track so whats the issue with it being illegal?"
y2kgtp is offline   Reply With Quote
Old 03-02-2009, 02:25 AM   #3
JeromeK99's Avatar
Honestly, if you are considering a race worthy stadium truck I wouldn't try to convert a Speed-T.
There are several budget minded brushless ESC/Motor packages out there for $150 or less... you can get better spread spectrum radios for around $100 and maybe a used XXX-T of one of many versions that have come out. This will get you a worthy vehicle with a proper motor to go with it.
For what you would have to spend converting a Speed-T to "stadium" status would be more than just buying a used truck.
Good luck!
Jerome
JeromeK99 is offline   Reply With Quote
Old 03-02-2009, 06:37 AM   #4
y2kgtp's Avatar
Good luck!
Jerome
Above points are all good ones....however I got my truck for 143$ shipped used on eBay for everything. So it's more of a fun "project" than anything....
and you can find the Truck for 239.95$ Shipped new in the box as well....
Old 03-02-2009, 07:15 AM   #5
rc east's Avatar
BMXRDAD
Me and my brother did successfully convert a speed-T and in the end its not a bad truck, but TRUST ME go and buy the xxx-t shocks, shock towers and body. (speed-T body wont fit with the new shock towers) The speed-T suspension is HORRIBLE off road, and you will break the speed-T shock towers first time out garranteed. Converting to a diff is also a must.(ditch the wheelie bar too). If your new to the hobby and on a tight budget it can be done.
rc east is offline   Reply With Quote
Old 03-02-2009, 07:28 AM   #6
y2kgtp's Avatar
Just curious on the shock tower breakage....was it a bad landing perhaps that broke it?
Old 03-02-2009, 07:37 AM   #7
rc east's Avatar
The front seemed to break easy from a simple roll-over probably because of the rake angle. The rear wasn't as bad but believe me the handling after the conversion was like night and day.
Old 03-02-2009, 07:44 AM   #8
y2kgtp's Avatar
I'll keep that in mind. I just want to see how this does as is. Obviously I have screwed around way too much on mine so curious on how it will jump and corner with the motor & battery moved around. I have a entire spare truck as well, so can just put it back to how it was to start with if I don't like it.
I built it so I have something to play with as my kids battle it out with their 2 Slashes.....
Old 03-02-2009, 09:01 AM   #9
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
they do make a xxx-t cr kit that might be your way to go
roadrashracing is offline   Reply With Quote
Old 03-02-2009, 09:45 AM   #10
y2kgtp's Avatar
That's my next step if I can't get the Speed-T to work well
Old 03-02-2009, 08:52 PM   #11
Thanks for the input.
Wow that is a very interesting set up! how does it work for you?
I stopped today at my LHS and looked over the speed t and an HPI Firestorm Flux and a Losi XXX-T CR if I were to choose today it would be the HPI.
Now I am waiting for the associated SC10 should be here mid month then I will make my choice.
BMXRDAD
Old 03-02-2009, 09:29 PM   #12
xDaRReLLx87's Avatar
Sure the Speed T works well on off road!!
However, your better off to buy the
XXX-T CR kit, all the parts on the Speed T
other than the chassis are hard and brittle
which also causes things like doggones to
break. My friend at the track has his speed-T
and I like how it drives.
really you just need to change the shock towers and
the shocks and you basically have a XXX T.
To make a Speed T good?
-Get offroad tires
-Get new Suspension arms
-Graphite arms
-Graphite chassis
-Shocks
-Ball studs and Ball cups for the XXX T
Not exactly cost effective, but if you use the speed T and do
not use my suggestions, you will constantly be breaking parts
as the Speed T is not designed to do off road
You guys must be to lazy to build a kit Your welcome to pay me to build one
xDaRReLLx87 is offline   Reply With Quote
Old 03-02-2009, 09:31 PM   #13
y2kgtp's Avatar
BMXRDAD
Not sure yet....as I just got my battery mount in today, so I can secure the battery in place. Just an idea I was tinkering with over the winter now and then.
I get a slight cogging off the line, then it's a bat out of hell after that. I am thinking of dropping in a Novak Havoc 13.5T to run in that class perhaps....
Old 03-02-2009, 09:36 PM   #14
y2kgtp's Avatar
-Get offroad tires
-Graphite arms
-Graphite chassis
-Shocks
I don't mind building at all....I got my Speed-T for $143 for Truck, Brushless ESC\Motor & 2.4Ghz DSM radio....Cheap fun project. If it does not work well, it will be a street toy and I will get a XXX-T CR or a X-60 Truck.
The chassis is not plastic either, it appears to be the EA3 Material same as the XXX-T CR....it's some sort of composite material.
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 09:43 AM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 11:26 AM
Tons of rc stuff for sale tons sell it all Munsonator08 R/C Items: For Sale/Trade 20 11-19-2008 03:21 AM
Losi Speed-T RTR versus Rustler VXL Nightrunner Electric Off-Road 17 09-18-2008 08:07 PM
HUGE sellout...R12, XXXS G+, XXX-T, XXX, RTR Stampede, MX-3 FHSS plus MUCH more! WisdomRacing R/C Items: For Sale/Trade 13 06-25-2008 03:29 PM
2007 Singapore Invitational Challenge 2; Marine Parade RCMC phlim Singapore R/C Racers 904 06-28-2007 06:13 AM
Orion V2 19T - Savage Hopup - RC10GT Brake disk - Speed Gem motor mbunker R/C Items: For Sale/Trade 9 06-07-2007 12:19 PM
