Old 02-26-2009, 09:07 AM   #1
Trader Rating: 26 (96%+)
Default wd-40 ball thrust bearings?
I've been testing different lubricants on ball diffs to find various feals. wd-40 on the thrust bearings has been working great for tight high bite tracks. It allows for a super loose diff that is still very tight.
party_wagon is offline   Reply With Quote
Old 02-26-2009, 09:13 AM   #2
Suspended
Why would you want a loose diff on a high bite track?
goodgoogly is offline   Reply With Quote
Old 02-26-2009, 11:10 AM   #3
desertbird's Avatar
WD-40 is not a lubricant as claimed, it is a solvent. I guess it will work as long as you don't mind re-applying it often. Even then light weight machine oil would be a better "lubiricant".
desertbird is offline   Reply With Quote
Old 02-26-2009, 12:57 PM   #4
Suspended
Went out to the garage and thoroughly looked at the can on the shelf and didn't see the work solvent anywhere but it did mention lubricant. Are you buying some kind of chinese brand knockoff wd40?
Old 02-26-2009, 01:00 PM   #5
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
What does WD-40 do?
WD-40 fulfills five basic functions:
1. CLEANS: WD-40 gets under dirt, grime and grease to clean. It also dissolves adhesives, allowing easy removal of labels, tape and excess bonding material.
2. DISPLACES MOISTURE: Because WD-40 displaces moisture, it quickly dries out electrical systems to eliminate moisture-induced short circuits.
3. PENETRATES: WD-40 loosens rust-to-metal bonds and frees stuck, frozen or rusted metal parts.
4. LUBRICATES: WD-40's lubricating ingredients are widely dispersed and tenaciously held to all moving parts.
5. PROTECTS: WD-40 protects metal surfaces with corrosion-resistant ingredients to shield against moisture and other corrosive elements.
www.wd40.com
Original RC 10T, T4, RC8Te, Tekin RX8. Losi Ten SCTE, Slash 4x4.
OG RC 10T is offline   Reply With Quote
Old 02-26-2009, 01:08 PM   #6
porkey's Avatar
Dude WD-40 is a cleaner not lube! You want to use real lube on your diff. Like AE's stelth lube, that's what you want to use not WD-40.
porkey is offline   Reply With Quote
Old 02-26-2009, 01:08 PM   #7
rcterp's Avatar
Trader Rating: 35 (100%+)
You're both right. WD-40 is a solvent based lubricant. It's about 50% mineral spirits (solvent) and about 15% mineral oil (lubricant).
Φ
Glitter Lidz - "My driving doesn't shine but my lid does!!"
rcterp is offline   Reply With Quote
Old 02-26-2009, 01:11 PM   #8
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
dude he is talking about using it on the thrustbearing not the diff.If your using stealth lube on your thrust assembly that has to be one nasty diff in 1 run.
*Vandal 4wd Late model*XXX-T sprinter*Micro scale specialties 1/24 'rock monster' crawler*MSS Micro-Rail*MSS Micro-Funny*MSS Micro-Outlaw*
2wdMod is offline   Reply With Quote
Old 02-26-2009, 01:17 PM   #9
desertbird's Avatar
It's lubricating qualities SUCK!
Old 02-26-2009, 01:21 PM   #10
desertbird's Avatar
In my book that's mostly Solvent
Old 02-26-2009, 01:25 PM   #11
rcterp's Avatar
The Majority Wins rule, I like it.
Φ
Old 02-26-2009, 01:41 PM   #12
OG RC 10T's Avatar
Dude, where's my car?
Where's your car dude?
DUDE, where's my car?
Old 02-26-2009, 02:24 PM   #13
desertbird's Avatar
Old 02-26-2009, 02:26 PM   #14
rcterp's Avatar
What's it say???
DDUUUDDDDEEE!!!!!
What's mine say???
SSSWWWEEEETTTTTTT!!!!!!
Φ
Old 02-26-2009, 04:40 PM   #15
porkey's Avatar
Haha. Red it worng. Well still I would just stick with the black grease that AE uses.
