Old 02-25-2009, 06:38 PM   #1
Super08Duty's Avatar
Default Emaxx Slipper clutch Slipping
Hello, im new to the forum but not to rc's. I recently installed a MMM on my Emaxx. Im only running two 7 cell nimh's right now. Every time i hit the throttle the spur and slipper pads just spin. I had the spur gear tightened down all the way but it still did it. Can someone help me out on this? Could the pads be bad or something? This is a new model emaxx running a 68T spur and a 22T pinion. Thanks in advance.
Super08Duty is offline   Reply With Quote
Old 02-25-2009, 07:39 PM   #2
Trader Rating: 21 (100%+)
About all you can do is to pull it and look at everything. If the pressure plates are glazed, use some fine sand paper to break the glaze. Add 6 more pegs so you're running all 12 (cheap hopup). I used run mine all the way tight.
Even with the 12 pegs I couldn't get mine to stop slipping. I replaced it with the RRP slipper and probs ended.
Duster_360 is offline   Reply With Quote
Old 02-25-2009, 08:34 PM   #3
What exactly are the pegs? little bit confused. Your saying i should try to sand down the plate a little bit? ill try that. Your using an aftermarket slipper clutch for the new emaxx, am i right? thanks
Old 02-25-2009, 08:41 PM   #4
Are you talking about the Robinson racing double disc slipper kit? I was looking into getting one but i dont understand how it works. Do you have pics of yours?
New traxxas e-maxx xsxracing Monster Trucks 439 09-05-2012 04:15 PM
