Old 02-25-2009, 02:11 PM   #1
rob martin's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to rob martin
Thumbs up Lipo question?
Just curious what amp's do you guys charge your lipos at?? Just seeing how everyone charges them.
rob martin is offline   Reply With Quote
Old 02-25-2009, 02:25 PM   #2
JeromeK99's Avatar
Here we go again...... (probably going to get tons of replies)
If you have a charger that has the proper LiPo profile (cc/cv) then it will set it for you by way of what you input for the capacity (mah) and number of cells/voltage. The charger will start at 1amp for every 1000mah of the battery, what is referred to as 1c (5000mah starts at 5amps). As the charger gets close to sensing a peak voltage, it steps down the amps until its done.
That pretty much it... so it should be pretty easy.
Jerome
JeromeK99 is offline   Reply With Quote
Old 02-25-2009, 02:47 PM   #3
rob martin's Avatar
k kool. im switching from nihm to lipos and didnt want to spend hundreds of dollars and make a stupid mistake. I bought the team checkpoint charger btw.
Jerome
Old 02-25-2009, 02:55 PM   #4
Rick Hohwart's Avatar
Follow the charging instructions that come with your battery. As mentioned, your charge rate will change depending on the capacity of the battery and amond different battery manufacturers. There is no single correct rate for all batteries although you can use 1C as a basic rule of thumb.
Rick Hohwart is offline   Reply With Quote
Old 02-25-2009, 07:46 PM   #5
Trader Rating: 21 (100%+)
Unless your lipo states it is capable of 2C charging, stick with 1C or less. Most lipos are 1C charge rates. Charging at higher rates can damage your lipo and you'll get less life than sticking with 1C charge rate.
For a 5000mah lipo, 1C charger is 5000/1000 = 5amps. A 2C charger woul dbe 10amps. I have a TC 1030 charger too - you'll need a separate balancer unless you're running Orions and I'd still get one anyway.
Duster_360 is offline   Reply With Quote
Old 02-25-2009, 08:52 PM   #6
gweed's Avatar
+1 listen to him he knows what he's talking about
kyoslo RB5/ novak motors/ LRP sphere/ m11/ orion 4800,3800,3600/ blazin chronic racing/wphukuall radio/ raikkonen body/ mongoosed km-mini inferno with the multiplex red ass servo that owns johnny b-main and drew/ now at lir the JDM zx-5 sp mugen edition
"team bad guys"
gweed is offline   Reply With Quote
Old 02-25-2009, 09:05 PM   #7
theanimaleide's Avatar
yes he has a few years of racing under his belt
Aaron Eide
Wells Fargo Home Team
theanimaleide is offline   Reply With Quote
Twin Cities Rc Club Winter Carpet Season Mark O'Brien Minnesota and North/South Dakota Racing 5118 Yesterday 10:22 PM
Tamiya TA05 Touring Sedan kentech Electric On-Road 11403 06-21-2017 04:10 AM
Ask Steve "The Evicerator" Weiss TeamButter Electric On-Road 7088 07-16-2011 06:01 PM
2009/10 Hurricane All-Star Carpet Series Kevin K Wisconsin & Illinois Racing 761 07-12-2010 08:27 AM
Victory R/C Hobbies, Green Bay, WI. Brian F Wisconsin & Illinois Racing 1242 01-26-2010 09:46 AM
2009 Electric On Road ROAR Nationals at Hobbytown USA "The Coliseum" mojoman Racing Forum 154 09-29-2009 08:08 PM
Another begginer/returning question mark in wi Electric Off-Road 21 08-12-2009 08:51 PM
