Old 02-25-2009, 11:00 AM   #1
rcwiretek's Avatar
Default novak 17.5 thermal problems
im running it in a xxx-t mf2
im running a 78 spur.... and i went all the way from 28 thru 34 pin gear
wont run for more than 4 min.....
SOMEONE HELP
rcwiretek is offline   Reply With Quote
Old 02-25-2009, 11:23 AM   #2
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Most fast 17.5 truck guys are running in the 6.00-6.5 FDR (spur divided by pinion times gearbox ratio = FDR)...if it's overheating at that gear, you probably have either a bad motor, bad ESC or something binding up in the truck (not necessarily in that order).
SOMEONE HELP
Turbo Joe is offline   Reply With Quote
Old 02-25-2009, 12:15 PM   #3
Agree, I'm running the same motor in a truck with an FDR of 6 and I've yet to hit 140 after a 5 minute run, usually 125-130.
bennybtl is offline   Reply With Quote
Old 02-25-2009, 01:46 PM   #4
Foxxrocket's Avatar
If you'er running the 17.5 SS, you should be able run it much hotter than that. Novak suggestes running at 160-170F. Some times I run it even hotter than that, and have not thermaled yet.
Send it to Novak and get it replaced.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 02-25-2009, 02:12 PM   #5
Trader Rating: 20 (100%+)
On my B4, I'm running 78T spur and 29 T pinion. It doesn't even get close to warm and it's slow as hell. Here is the formula for FDR=Spur T / Pionion T * Internal Ratio (B4=2.6)
Based on this, I need to run around 34T Pinion.
I think, you may have a problem with your electronics. Check the wires. Is the sensor wire loose?
"Slow is fast." I drove slow but why am I still slow?
javacrazy is offline   Reply With Quote
Old 02-25-2009, 03:14 PM   #6
Turbo Joe's Avatar
No, you just need to gear it right. They need around a 5.0-5.25:1 in a buggy. When you gear them right, they're anything but slow.
http://www.speedtechrc.com/store/ebp...id=322&id=7716
65-67 spur and high 20's pinion with the motor in the front of the plate, not jammed against the guard.
Old 02-25-2009, 03:17 PM   #7
Turbo Joe's Avatar
That's the hottest they recommend, not the target. Some run hotter, some run cooler...but most aren't at 160+. Charlie always recommended the "6 second rule": If you can keep your finger on it for 6 seconds, it's not too hot.
120-150 is pretty reasonable from what I've seen.
Old 02-25-2009, 06:13 PM   #8
yupwhateverusay's Avatar
I find the higher you gear the 17.5 the better it works.I currently run the 72 spur 34 pinion on my B4 buggy and the motor is crying for more so i'm going to try the 36 pinion .with the 34P the hottest it gets is 110deg after 15 min
yupwhateverusay is offline   Reply With Quote
For sale/trade thread UnderDaHill Nebraska/Iowa Racing 5234 12-08-2017 05:01 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
kyosho electric offroad b-man777 Electric Off-Road 9014 12-22-2012 08:36 AM
Associated Factory Team TC5, Brushless, LiPo, Li-ion Nanophosphate, Tips and Tricks John Stranahan Electric On-Road 839 11-01-2011 04:31 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 11:26 AM
10.5 Brushless help please TheCoolCanFanMan Electric On-Road 7 12-21-2007 12:15 PM
