Zippy 5s 5000 charging question? >
Old 02-25-2009, 08:56 AM
Trader Rating: 83 (100%+)
Default Zippy 5s 5000 charging question?
For the zippy 5s 5000 batts is 5amps the max I can charge it at? I am jumping from 2s 8000 and was told then that it is 1amp per 1000mah but am not sure if this holds true regardless of how many cells?
bigbeej is offline
Old 02-25-2009, 09:12 AM
trdsupra88's Avatar
Trader Rating: 25 (100%+)
5 amps is the maximum you would charge that pack at.
trdsupra88 is offline
Old 02-25-2009, 11:27 AM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
+1 . Don't forget to up your cutoff voltage too for the zippys to keep them running well. 3.3V per cell seems like a good starting place.
Cain is offline
Old 02-25-2009, 11:32 AM
I have always run at the 3.2v per cell mark on my 2s setups. For 5s I am setting teh cuttoff for an even 16v? Sound about right?
bigbeej is offline
