Castle Mamba Monster + Zippy Lipo's = SMOKED >
Old 02-23-2009, 03:26 PM
  #31
Trader Rating: 46 (98%+)
Originally Posted by hobbipro View Post
I had the first version of monster when it came out, I've followed its progression up till V3. Castle has and always will blame the battery Mfg. Mine never went thermal, I sold the truck it was in, but seems the V3's are doing pretty good now with the occasional one that still melts down. They always come on rcmonster and say it was the battery to blame, some sort of ripple effect from the batteries makes the capaciters blow up. Good news is that Castle will repair it, bad news is that it may happen again. I've heard of guys going through 3-4 of these until the problem was solved, but honestly lots of those people were having BEC failures.
Just to add a little more to this story the first CC Monster I had broke on me in 10mins the casing came apart. I called CC and they sent me a ESC out before I even shipped it back. The tech told me they are having a few issues and I should have zip tied it in. Also he mentioned to take the sticker off the bottom. Makes sense to mee since the ESC cover and circuit board was flopping around while the sticker was still stuck to my double face tape. That was great service.
Funny thing is later that night same thing happened to my buddy and 2 others. My buddy got the same story zip tie yad yada yada and they sent him a new one. So far we were pleased but still baffled at the design.
The tech told him since this is the second ESC he is replacing that if it blows up again they cannot send him another and he also said to not zip tie it in anyways this just kinda sucks.
everyjuangohome is offline
Old 02-23-2009, 03:44 PM
  #32
Team Tekin
Tekin Prez's Avatar
Bingo! Basic V/R=I Divide 14volts by the resistance of your motor, should be a couple thousand amps which obviously does not happen, but some other pretty aggressive things do. It is not the power from the battery or a huge current draw that would puff the battery and cook the fets. It is a voltage ripple that happens almost instantaneously. Things turn on that should not be on and then the big current flows causing the excitement.
I am not defending or attacking anyone. Just educated and protecting ourselves since this is a real issue we will likely face as well.
Why do you think some 1/10 controller have a gas can sized capacitor or array of capacitors and are only rated to 7cells when they have the same fets as these controllers? We are doing some pretty amazing things with a lot of power in this application. It is reasonable to require a decent power supply to make it happen reliably.
Tekin Prez is offline
Old 02-23-2009, 03:46 PM
  #33
Trader Rating: 62 (100%+)
theyll be more companys coming out with speedos in the next few months castle is not the only company out there guys ......my two speedos from castle have had many problems shorted fan wires board problems .....give it time some one will come out with a better speed controller......
oneblackram is offline
Old 02-23-2009, 03:52 PM
  #34
boy sounds like tekin is having problems also hmmm wonder if castle is making boards for tekin????????????also my first speedo came apart also bought it off a guy that was another one that came apart ....guess what not under warranty because it was second hand brand new though ....70.00 bucks thanks for coming ......
Old 02-23-2009, 03:54 PM
  #35
kufman's Avatar
I will not claim that any products are junk and will not work, but it is a technical fact that lower quality batteries are hard on electronics. They are a concern and liability for those of us that make controllers. If a battery is over rated or over stressed the voltage will bounce to very high levels and stress the caps. If the caps blow the voltage spikes can exceed the limits of the fets and the speedo will blow. Many of you are looking at things with data loggers that take 20 samples per second or less. We are talking about voltage ripple that happens in micro seconds that can bounce off the scope thousands of times per second with no caps. The fets are only rated to 30V.
Like it or not it is a real engineering problem to deal with in car controllers. Airplane controllers are not the same animals and are not switching the same in most cases. They also do not freeze the motor with brakes and slam full throttle on a 1 turn motor.
Tekin Prez
Sound like the real answer is caps that can handle higher ripple current and possibly a transorb to protect the FETs in the case of a cap failure. Maybe the addition of an "Excessive Ripple" circuit too. Unfortunately, this adds to the cost, size, and complexity of the controller. If cheap lipo can cause an ESC failure, how did these things ever run on NiMH?
We do the opposite of a brushless esc at work and we have to protect our filters very carefully. A 4MW power supply feels no pain destroying just about any filter that is put onto it. We have to use excessive ripple and excessive 60Hz trips along with circuit breakers on the cap bank in order to keep things in one piece.
kufman is offline
Old 02-23-2009, 04:04 PM
  #36
Company Representative
....Why do you think some 1/10 controller have a gas can sized capacitor or array of capacitors and are only rated to 7cells when they have the same fets as these controllers?....
Wonder who this could be?
NovakTwo is offline
Old 02-23-2009, 04:09 PM
  #37
drperry's Avatar
If the motor just locked up out of nowhere... Either something got stuck in the gears, and fell out once the power was lost and not keeping it between the gears...
I don't think I've ever seen an ESC pop and slam on the brakes, usually it just coasts to a stop...
Unless the voltage ripple locked up the brakes, or slammed it into full reverse.
drperry is offline
Old 02-23-2009, 04:13 PM
  #38
YDBD's Avatar
Heya,
Good thread, running the zippy 5000mah 4s with MMM and 2200kv, smoked the zippy, but not due to the battery spiking. The tray ripped out and the lipo hit the steering post and shorted. I since created a case to avoid this user error.
As reviewing the hobbycity website I concur on all the positive feedback that is posted there, but I also believe that all of us are running pretty new untested by the masses power systems. By anymeans we may be the Beta testers for some of the companies. I believe Castle puts out a quality product and stands behind it with great service because they know it hasn't be tested in ALL vehicles.
This is why we have the "expert" forum, we try new stuff and we do not test lightly and we take the risk of losing some cash and a car.
My offroad kit now has a welding glove and a nice bucket of beach sand.
Never going nitro...too slow...too messy....too noisy....too expensive....
YDBD is offline
Old 02-23-2009, 04:16 PM
  #39
Team Tekin
Tekin Prez's Avatar
Oneblackram – Cheap shot. We are not having problems. I am just stating the facts from an engineering standpoint.
NovakTwo - Too Funny, sorry about the gas can comment. I was making a point that it must be diffcult to deal with.
Well you have the 3 companies that actually design controllers for a living here. You can learn or argue opinions and bash. It’s real and a challenge for all of us. Some here obviously understand it and hopefully other non posting readers are getting it also.
Old 02-23-2009, 04:26 PM
  #40
Oneblackram Cheap shot. We are not having problems. I am just stating the facts from an engineering standpoint.
Well you have the 3 companies that actually design controllers for a living here. You can learn or argue opinions and bash. Its real and a challenge for all of us. Some here obviously understand it and hopefully other non posting readers are getting it also.
Eh ignore Oneblack. I for one appreciate the points you have mentioned in this thread and as a business owner agree with the steps you are taking and admitting in order to develop a nice product.
Old 02-23-2009, 04:32 PM
  #41
sorry team tekin ill be trying your stuff also when it comes out just like everybody else is doing .....i know it just takes time and money ...i do hope that your case is screwed in not snapped in like the castle ......were all spending lots of money also out here ..and face it some of these things are going to blow up its the nature of these beasts .......tekin has always made great products raced them for years till they closed down ......ive ran most all of them ....
Old 02-23-2009, 04:41 PM
  #42
How bad is that design on the Mamba monster. Plastic clips. Especially here in socal where tracks are like supercross tracks. I cannot belive they did not use screws to hold the ESC case together. No joke I was on the driver stand and told another guy running a mamba "hey you might want to secure your esc with more than the double face tape, mine blew apart" 5 seconds later his did the same thing.
Old 02-23-2009, 04:53 PM
  #43
yes you would think they would a least give you zip ties in the box and tell you to use them cause there cases fall apart ....i ran my first one one lap mean 1 lap 20 seconds of run time came apart and the dam thing hit my metal servo horn and it broke the speedo ....castle said send it in and they will replace it .....ok so i did that will be 70.00 bucks please cause i bought my buddys spare that he sent in for a replacement 165.00 plus 70.00 bucks thanks for coming what a warranty .....my second one is zipped tied in and velcroed in for cushion .......still working for now... i wasnt trying to slam tekin i havnt tryed there product but i will when it comes out ......
Old 02-23-2009, 04:57 PM
  #44
YDBD's Avatar
thanks for the case tip on the mamba monster, will be securing mine with some extra zip ties, duct tape, maybe even gortex...
YDBD is offline
Old 02-23-2009, 05:07 PM
  #45
Super Moderator
nexxus's Avatar
Trader Rating: 310 (100%+)
so far I have seen a guy start a thread based on "what his buddy said and did
and people push SMC batteries to the utmost, last pack of SMC I had was IB4200 matched Nimhs and one cell vented and another exploded, so no battery company is perfect.
I've emailed castle myself as I was looking at Zippy packs for my Savage flux, and will go on their advice as to whether or not these packs are usable with the speedy.
But inevitably sometimes a speedy can just blow, it happens thats why there are warranties, dry solder connections, faulty components etc it can happen. Isn't it possible that's the case here?
nexxus is offline
