Pinion gear for B4
Old 02-23-2009, 01:26 AM
dameetz's Avatar
Default Pinion gear for B4
I just got my self a B4 in a trade with my friend. Its brand new in a box and at the moment I m in the process of building it. I really don't know anything about this kit. My q is what type of pinion should I use with it, and how many teeth? I ll be putting my 5.5T BL motor in it. Also if you have any advice during building, pls do so.
Thanks.
dameetz is offline
Old 02-23-2009, 03:29 AM
MiCk B's Avatar
Hey,
The 5.5 will be too much for the b4, it will be un-drivable.
You would be better with a 7.5 (geared 23/81)
MiCk B. :-)
MiCk B is offline
Old 02-23-2009, 06:17 AM
MiCk B is correct, a 5.5 brushless will be very hard to control in a 2wd off-road car.
Anyways, you can go here for a guide to gearing your brushless motor.
CraigV is offline
Old 02-23-2009, 06:45 AM
dameetz's Avatar
Thanks for the info guys...will try to get another motor..at the moment thats the only one I have laying around...anyhow what pitch pinion should i get?
dameetz is offline
Old 02-23-2009, 06:48 AM
48p
Norris is offline
Old 02-23-2009, 09:18 AM
dameetz's Avatar
dameetz is offline
Old 02-23-2009, 09:08 PM
Trader Rating: 19 (100%+)
Thanks.
When you get to the part of putting together your shocks, buy green slim for the O-rings. Helps not to leak oil out.
b4wires is offline
