Old 02-19-2009, 06:34 PM   #1
brickshouse's Avatar
Default Li-po batteries
can someone please explain what all the numbers mean about the li po batteries?? 20c 25c 30cetc? 2s 6s? charge rate 1c? and the small set of wires coming out besides the battery leads???: This is all too new for me. Could you also recommend a good semi cheap charger for a 6 cell pack of these???? Do you need a different charger for the higher voltage li po batteries?? What do ya do when there is no leads coming from the batteries??
brickshouse is offline   Reply With Quote
Old 02-19-2009, 07:13 PM   #2
TNS Racing's Avatar
check the other 10000000000000000000000000000000000000000000000000 threads that ask the same question
the true purple and yellow
Team Associated/ Seidel Racing/ Team Scream Racing/ Nike 6.0/ RC Madness
b4.1 novak gtb/ velociti 6.5r
b44.1 lrp sxx tc spec v2/ velociti 5.5r
TNS Racing is offline   Reply With Quote
Old 02-19-2009, 07:16 PM   #3
gndprx's Avatar
Trader Rating: 18 (100%+)
1C = 1 x Battery Capacity. i.e. a 5000mah pack has a 1C of 5A.
So a 1C charge for a 5000mah pack = 5A charge rate. 2C = 10A etc...
The high C value printed on the pack is the discharge rate. The higher the value, the higher discharge capability. 4000mah pack with a 30C discharge rate = 120A. Some packs will print the burst rating, others will print the constant discharge rating. Depends on the manufacturer.
S is the number of cells in Series. 1S is 1 cell. 2S is 2 cells in series (7.4v), 6S = 6 cells in series, etc...
2S2P pack would be 2 series, 2 parallel cells. usually you'll see this in packs with greater than 5000mah capacity. i.e. a typical 8000mah pack will be a 2S2P configuration.
The smaller set of wires with the white connector are for balacing. When you have more than 2 cells in a pack, they require balancing to keep the cells at the same voltage. You don't want the cells to drift or they can be damanged by over charge/discharge if one cell is significantly out of balance.
Carl Fisher
Team Xtreme RC
The Grove Racing Center
gndprx is offline   Reply With Quote
Old 02-19-2009, 07:17 PM   #4
The "C" rating is the mAh of the battery divided by 1000 multiplied by that # (20C, 30C, etc.) and is the amperage that battery can output, whether it be max or continuous.
Each "S" is a cell,with each cell being 3.7 volts, so 1S is 3.7 volts, 2S is 7.4 volts, etc.
The charge rate is the same thing as output "C"'s, except for how fast, or at what amperage you can charge it.
The small set of wires is for a balancer, I believe, which makes sure all the cells receive the same charge, and that one is not being over- or under-charged.
howtowakeakar is offline   Reply With Quote
KO PROPO EX-10 Helios q's Kenshin Electric On-Road 2225 03-13-2014 02:04 AM
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 11:23 AM
Team Orion goes Li-poly. Mabuchi540 Electric On-Road 125 09-13-2006 10:20 AM
ROAR On Road Rules Discussion TimPotter Chat Lounge 126 03-21-2006 03:19 PM
Team Entity Racing 1/10th car Team Entity R/C Items: For Sale/Trade 38 04-11-2005 06:53 PM
Privateers dmatter Electric On-Road 78 03-25-2005 09:23 PM
