brushless motors
Old 02-18-2009, 05:58 PM
brickshouse's Avatar
Questions?? brushless motors
Do i need any kind of adapter to fit the novak brushless motors into my t4? Do the regular pinions fit on these motors as well???? Thanks
brickshouse is offline
Old 02-18-2009, 06:06 PM
JeromeK99's Avatar
Same screws... same pinions.. though gearing is different and you will probably need a different range of spurs and pinions than you are used to with brushed.
Jerome
JeromeK99 is offline
Old 02-18-2009, 06:12 PM
No, you don't need any special adapters, but you will have to change your gearing. If you're running a 17.5 or 13.5 brushless you should be the new smaller 72 or 75 tooth spur gears.
Yes, regular pinions fit them. Go here to figure out what pinion/spur you should use.
CraigV is offline
