Old 02-18-2009, 04:12 PM   #1
rook-e's Avatar
Default Reedy Challenger 19T
Well I had posted a question about this motor a few days ago but now I cant find it. So here it is again. I recently returned to racing a couple weeks ago after taking ten years off, so I am a little out of tune with the whole Lipo batteries and brushless set ups. Heres what I got, I bought a FT B4, DX3S, and Reedy 5000mah 35C Lipo and a Reedy Challenger 19T I finally opened the plastic wrap on my now vintage LRP 7.1 esc (1999). Heres the problem, neither my esc or my motor is getting hot, but the car will only run for about five laps then gets real slow and then stops, so clearly my brushes are sticking. So I clean the com and the motor and it repeats.
Is this caused due to too much discharge (35C)?
My gearing is spot on for this motor so I can only assume that the battery is the problem. Is there a better brush that I can put in here and maybe sacrafice com life but be able to finish heats and 15 minute mains?
Any help would be great as I already signed up for the Cactus Classic at SRS Raceway and my funds are depleated and cannot afford to buy a brushless set up.
keyboard cowboy: defined; a person who has a not so rare element that makes one powerful and mighty in front of a keyboard, yet VERY cowardly in public, this element is known as "Afraidium"
rook-e is offline   Reply With Quote
Old 02-18-2009, 04:32 PM   #2
B-FAST R/C's Avatar
To find your post or threads
Click on your "name" in a thread or post.
On the right side of the page under " mini statistics" click on "show all statistics". You will see a link for all your posts and threads in the center of page.
Here ya go!
http://www.rctech.net/forum/radio-el...ush-eater.html
www.bfastrc.com *** Feel The Diff!! ***
arcshobbies mcculloughsrcracing
B-FAST R/C is offline   Reply With Quote
Old 02-18-2009, 05:37 PM   #3
TNS Racing's Avatar
that reedy motor is absolute trash. its non rebuildable so now since your brushes are done, your whole motor is done
the true purple and yellow
Team Associated/ Seidel Racing/ Team Scream Racing/ Nike 6.0/ RC Madness
b4.1 novak gtb/ velociti 6.5r
b44.1 lrp sxx tc spec v2/ velociti 5.5r
TNS Racing is offline   Reply With Quote
Old 02-18-2009, 06:01 PM   #4
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Too much discharge..NO 35c is not a measurement of the OUTPUT of the battery but a measurement of the rate at which power can be pulled from it by the motor. Efficiency of the battery basically...make sence?
5000x35/1000=175
[email protected] =175 max amp draw
Others feel free to correct me if this is wrong or if you can explain it to him better.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 02-18-2009, 06:03 PM   #5
TNS Racing's Avatar
why do you divide by 1000?
Old 02-18-2009, 06:07 PM   #6
Super Moderator
racer1812's Avatar
To get from mah's to amps. I'm not the best guy to ask about comparing mah vs. amps.
Old 02-18-2009, 06:15 PM   #7
RC Dad's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to RC Dad
TNS:
The Challenger is easily rebuildable, and has gotten some good reviews.
The 1,000 divide is the conversion factor from amps to Milli-amps (sp?)
rook-e:
If your brushes were hanging, you're motor would definitely be getting hot, as it would if you had bad bearings or other binding issues. If the battery is known to be good then it's likely a wiring or connection issue.
What kind of connectors are you using? If you've got the 1999 era Tamiya white ones, they only handle 15 amps and I'd bet they're melted together. I'd upgrade to Deans (or even the new Traxxas or Losi ones) that are made to pass higher loads and see if that takes care of your problem.
GV2 Pro, XXX4G+, Blitz SCT, CRC GenXL
RC Dad is offline   Reply With Quote
Old 02-18-2009, 09:05 PM   #8
rook-e's Avatar
I am running the bulletconnectors that push directly into the battery. And it is wired up exactly as the LRP instructions say/show to. The tranny/diff is free moving as it should be, no binding to be found. And the motor is not getting hot. The battery is brand new only charged three times on a balancing charger. I went ahead and went through the set up again on the ESC, no change.
The other day I charged the battery and ran it in the parking lot for approximately 2 minutes, if that and it shut down. I have tried a smaller 4000mah 20c lipo and nothing changed.
The motor ran perfect once, and that was first time I used it and it ran the whole pack without any problems. The second charge is when the problem started.
Is it possible I just got a bad one?
Old 02-18-2009, 09:29 PM   #9
KostaG's Avatar
Trader Rating: 48 (100%+)
I think you should more worried about running lipo with an old speed control that had no lipo voltage cutoff. 2 cell lipo should never go under 6v.
As far as the run time issue, have you had this since the first run of this setup?
Current Cars:
- Schumacher SX3 & Cougar SV
- Mugen MRX5 WC, Serpent 966e (4s)& Motonica P81e (6s)
Collector/Vintage Cars:
-Serpent F180 (2x), Serpent Veteq, Losi Jrx2, Tamiya Avante & Associated RC10
KostaG is offline   Reply With Quote
Old 02-19-2009, 06:16 AM   #10
TNS Racing's Avatar
hold up is it:
amps to milliamps
or
mah to amps
Old 02-19-2009, 07:48 AM   #11
Super Moderator
racer1812's Avatar
1 amp = 1000 milliamps (mah= milliamp hours) electrical measurement of a batteries capacity.
Old 02-19-2009, 11:12 AM   #12
OTE_TheMissile's Avatar
Send a message via MSN to OTE_TheMissile
I already have a thread going about the Challenger's brush problems: http://www.rctech.net/forum/radio-el...ush-eater.html
I've had 2 of these motors and they go like mad when new, then suddenly go flat and lo and behold, there's NOTHING left of the brushes.
But the 2 that I've had were purchased right after the motors were released, one guy on my thread says he's had a bunch of runs through his and no problems, so I'm thinking that Reedy made a production change to a more durable brush. Haven't had any confirmation on that, so I'll wait and see before giving the Challenger another go.
Faster Than Factory
On The EDGE Racing, est. 2001 - Home of the 524, the Silverado Slammer E-MAX6X6, and the Sand Dollar prerunner
Mike Budzien | facebook.com/OTE.TheMissile | RIVCO Products | The RC Corral | iRacing.com
OTE_TheMissile is offline   Reply With Quote
Old 02-19-2009, 08:40 PM   #13
rook-e's Avatar
As far as voltage cut off on the old esc I ran the car until I couldnt easily make the doubles, then I pulled it. And this is the only set up that I have run in the car because I have only run the car the one race and thats when the problem started, pretty much immediately.
Team Br00d Racing Motors peter_robinson Team and Company Discussions 4435 01-06-2014 09:04 PM
Novak GTX and Reedy Challenger 19t RC-DriftNewb R/C Items: For Sale/Trade 17 04-21-2009 06:57 PM
Sellout part 2 ovalnator R/C Items: For Sale/Trade 21 04-17-2009 06:49 AM
Sellout ovalnator R/C Items: For Sale/Trade 33 03-11-2009 09:32 AM
Reedy's new Stock Motor (Stockstar) CaliberX Electric On-Road 159 11-05-2008 04:27 PM
