B4 Lightweight setup >
Old 02-16-2009, 06:19 PM
Default B4 Lightweight setup
Can someone tell me exactly what the b4 lightweight setup is. What mods i havetomake to the car any weight aadded for using lipos or light lipos ? and whats the advantage
aquafina1 is offline
Old 02-16-2009, 06:30 PM
Trader Rating: 26 (96%+)
Add like 2 ounces right in front of the transmission & then add the rest of the weight to meet reg to the left & right of your battery trey.
party_wagon is offline
Old 02-16-2009, 07:08 PM
how about all the camber location,shocks,etc... washers,springs
Old 02-16-2009, 08:07 PM
CCristo's Avatar
Trader Rating: 56 (100%+)
No weight in front of the tranny.
http://67.199.85.166/racing/setups/b...crcrc_2009.pdf
CCristo is offline
Old 02-16-2009, 08:14 PM
Ty
Ty's Avatar
Trader Rating: 32 (100%+)
Is the T4 setup going to be posted soon from this race? Thanks.
Ty is offline
Old 02-16-2009, 08:17 PM
CCristo's Avatar
I think the team used Cav's 06 nats setup at CRCRC.
CCristo is offline
Ty
Ty's Avatar
Any changes to the 2006 setup for lipos?
Ty is offline
Old 02-16-2009, 09:42 PM
quick question on what limiterers are for the shocks ? on the b4 setup sheets it always says like #1 or #2 or whatevr what exactly are these
sszzxx is offline
Old 02-16-2009, 09:51 PM
Trader Rating: 23 (100%+)
Correct.
AxiomJacob is offline
Old 02-16-2009, 10:06 PM
wayboarder's Avatar
Trader Rating: 14 (100%+)
I talked to pudge a few weeks ago right after the crcrc race about the light setup and he mentioned it being on the associated website. I havent found it yet but from what I recall it was the same setup as the 06 but with the lightest rear spring as well as 1.5 ounces of lead in the back. On the rear shock tower you add another hole at about the same distance as the rest to make a more inboard shock setup. Next time I hit the track I will hit him back up.
disregard, the setup is at this link
thanks CCristo
wayboarder is offline
Old 02-16-2009, 10:49 PM
No they didn't. I think the setup is pretty different.
DanGriffin is offline
Old 02-16-2009, 11:04 PM
teambighead's Avatar
The set up posted on AE's web site for CRCRC 2009 is the 'light weight' set up.
Keep in mind, that the 1/2 degree rear hubs are not a must if your track has lots of rear end grip.
The truck set up is being worked on...
teambighead is offline
Its the 2009 crcrc set up. i ran it last weekend at the "big kahuna" and its really really good. the only thing i did was take the washers out under the rear ballstud. i also made sure the car weighed 1510g with my lipos just like the set up.
Racers Edge makes the hubs.
john oliver is offline
Old 02-16-2009, 11:08 PM
Tech Legend
Wild Cherry's Avatar
Is it true?
When they use the .5 they also use a different pivot block ?
also
Which hole on the rear .5 hub are they using for the camber link ?
Wild Cherry is offline
Old 02-17-2009, 04:38 AM
CCristo's Avatar
For truck? As I posted above, the buggy setup is much different, but the question was what setup they used for truck.
CCristo is offline
