Old 02-16-2009, 04:18 AM   #1
Colin8ight-E's Avatar
Default What pitch is the Losi 16 tooth Pinion
Does anyone know what Pitch the Losi 16 tooth pinion is. Also is there another brand that will fit the MMM 2200KV motor?
Colin8ight-E is offline   Reply With Quote
Old 02-16-2009, 05:18 AM   #2
wfdfiremedic's Avatar
Mod 1
wfdfiremedic is offline   Reply With Quote
Old 02-16-2009, 12:35 PM   #3
Old 02-16-2009, 04:25 PM   #4
kufman's Avatar
Are you using the Losi motor plate? I have noticed that some pinions may hit the stock Losi setup because the grub screw sticks out farther than the Losi pinions. The Losi pinions use a 3mm screw where all the other use a 4mm. RC-Monster, Robinson, Novak, and a few others make Mod 1 pinions with 5mm bore for the 1/8th scale size motors.
kufman is offline   Reply With Quote
Old 02-16-2009, 11:56 PM   #5
Yeah I have a 8ight-E with a standard pinion and standard 45 tooth spur gear.
I'm running the MMM gear in it.
I find the only problem i have with the Losi Pinion is the grub screw, it doesn't seem to tighten on the shaft properly and then the grub screw will round off if it's done up to tight.
Old 02-18-2009, 08:53 AM   #6
I went with a Novak pinion because of this. Novak's have a larger grub screw which you can tighten down better.
Old 02-18-2009, 10:42 AM   #7
kufman's Avatar
Everybody except Losi uses 4mm set screws. I can't figure out why they didn't!
NR Vintage RC10L & RC12L Parts lot Many manufactures!!! Herc1999 R/C Items: For Sale/Trade 29 01-28-2009 01:51 PM
New Operation cost? Trover Electric On-Road 22 08-01-2006 05:56 PM
