Old 02-15-2009, 05:58 PM   #1
jd267's Avatar
Trader Rating: 36 (100%+)
Default t4 and b4 qestions?? thanks guys
guys im looking to put 5700 systems in my rc10s.. do they have an upgrade aluminum gear set for the tranny/diff for these... let me no guys
jd267 is offline   Reply With Quote
Old 02-15-2009, 06:40 PM   #2
Send a message via AIM to MMT4 Send a message via Yahoo to MMT4
Default No Need.
I'm pretty sure you'll do fine without metal gears in your tranny. I've got a 6900 with punch control disabled running 7 cell matched packs and my tranny is still intact, no shredded gears. Make sure your slipper is properly adjusted, along with your diff. Doesn't have to be super loose, but in tune.
MMT4 is offline   Reply With Quote
Old 02-15-2009, 07:00 PM   #3
Trader Rating: 26 (96%+)
yeah, the only thing that can cause you problems is your diff slipping & causing your diff gear to melt. If you have money to spend then purchase a set of ceramic diff balls & thrust bearings. You should be able to find a set of them for under $25. These will make your diff much easier to dial in & tune.
party_wagon is offline   Reply With Quote
Old 02-15-2009, 08:06 PM   #4
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
they are both BL ready...in high bite situations the diff could bark, if so, tighten it until it doesent...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 02-17-2009, 03:36 PM   #5
jd267's Avatar
i here you guys.. im just weary because i had a stamped with a 12 turn traxxas junk motor and xl5 and blew the tranny apart.... i had to put the upgrade idle gear and diff... thats why i was asking
Old 02-17-2009, 04:09 PM   #6
porkey's Avatar
Well thats traxxas. AE gears are hella strong. I seen people but 5.5 motors to these thing and had no trouble. You will be fine with the stock gears.
porkey is offline   Reply With Quote
