Old 02-15-2009, 03:36 PM   #1
Send a message via AIM to MMT4 Send a message via Yahoo to MMT4
Default Associated Shocks
Hey all, my second hand t4 has the silver aluminum shocks (stock?). They seem to have alot of air in them, is this normal? I've always been used to using shocks with air bladders, and they aren't supposed to have air in the shock oil itself.
Thanks.
MMT4 is offline   Reply With Quote
Old 02-15-2009, 03:54 PM   #2
Trader Rating: 42 (100%+)
Did you rebuilt or just changed the oil? If you follow the instructions, there will be some air in them. That's how they work. If they are hard to get them to rebound 1/4", you'll need to rebuild them.
desertraton is offline   Reply With Quote
Old 02-15-2009, 04:11 PM   #3
I have never touched the shocks since the trade I got them in. They seem to work great, I'll see if they rebound the specified length.
Old 02-15-2009, 09:08 PM   #4
BuggyKing's Avatar
Trader Rating: 17 (100%+)
when u rebuild the shocks u should get all the air out. Fill the shock bodies almost to the top and pump the shock shaft up and down. You will see air bubbles come to the top. I then fill body all the way up. Then put some in the shock tap and screw on. Screw it until it is threaded almost all the way on. Then compress shock shaft all the way and tighten cap up. There u go.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 02-16-2009, 01:58 AM   #5
RCRat's Avatar
Send a message via AIM to RCRat Send a message via Skype™ to RCRat
Thanks.
A GREAT...How-To...bookmark this one!!
http://users.telenet.be/elvo/12/8/1.html
RCRat is offline   Reply With Quote
Old 04-02-2009, 11:42 AM   #6
stitchy's Avatar
Originally Posted by Wild Cherry View Post
stichy, Ae shocks are still the best materials & design available...
All shocks need rebuilding , not just Ae ...
The reason ?
Silicon Shock Oil
The rubber O-ring`s swell because of the oil....
This is why I recommended the Green Slime from Ae , you coat the ring`s with the grease and it help protect them from the oil....
Most forget to use the Slime and this is why you hear complaints with oil leaks...
Ae shocks actually perform better than the K car shock as well !
Why ?
Because they are a "emulsion" design and this is why Ae shocks are smoother & more plush on the bumps than a shock equipped with
bladders such as the K-car....
I've decided to move the discussion here.
Wild Cherry, if AE's o-rings are rubber and swell when used with silicone shock oils, do you think silicone o-rings (a la Kyosho and others) would be better? Have you ever tried them?
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 04-02-2009, 11:50 AM   #7
Trader Rating: 58 (100%+)
I've used AE shocks for years, but the best thing i've found is bleeder caps. I forget the brand, I want to say yocomo. It eliminates horsing around bleeding them. Very easy to get the exact rebound you want & no air provided seals are good & shafts are ok.
Where ever I may roam
Bigcheese is offline   Reply With Quote
Old 04-02-2009, 11:56 AM   #8
Tech Legend
Wild Cherry's Avatar
Ae O-rings are not rubber, there "silicone" O-rings....
Wild Cherry is offline   Reply With Quote
Old 04-02-2009, 12:23 PM   #9
xDaRReLLx87's Avatar
http://www.youtube.com/watch?v=rixBJu93Qyw
^ All you need to know. There is also a video on how to perfectly glue tires as well. Good luck and besure to bleed your bubbles out when you build your shocks. Clean the inside with windex and rubbing alcohol.
Good Luck!!
Hyper 9E 2000KV T8/RX8- 4S Turnigy 4500 mah
Ko ProPo EX-1 UR 2.4 ghz, Hitec-7950TH
xDaRReLLx87 is offline   Reply With Quote
Old 04-02-2009, 01:46 PM   #10
I have built my AE shocks with green slime alot, btw I hate AE shocks. But I was wondering if anyone has tryed the Mobil 1 grease? Like you use in 8th scale diffs to coat the O rings and help prevent leaks. The red stuff, I forget the eaxt name or it.
Josh
JoshM20 is offline   Reply With Quote
Old 04-02-2009, 03:19 PM   #11
Josh
You only use that for installation purposes. I have never heard of red grease unless you are referring to Loc-Tite!! The O rings are generally good enough to prevent leaks, if installed properly. Now putting geese in the O rings in the preload adjuster nut, is a standard procedure.
Old 04-02-2009, 03:28 PM   #12
Lol, I think I know the difference between loc-tite and grease. I'm not sure how you have never heard of reg grease before but here you go. It's called Mobil 1 Synthetic Grease.I use it in all types of ways (on RC cars) and real ones. If you have worked on a car before you should know what it is also.
What are you talking about, pre-load adjuster nut? I'm guessing you are talking about the preload nut for threaded shock bodies. Yes, you should always do that.
I don't understand your thought on, something being for installation purposes and not a rebuild purpose. You must not mess with AE shocks much, they are notorious for either, Leaking, Blowing, or Coming from the factory defective. If you get a defective shock body, it does not matter if you installed it properly or not, it is going to fail, and fail quickly.
Old 04-02-2009, 03:38 PM   #13
Suspended
"O rings in the preload adjuster nut"
What are you talking about?
We've been using AE Green Slime (grease) on the shock O-rings for years to aid in assembly and to help stop leaks from O-ring damage during assembly, whether they are "installed properly" or not.
Lightin' is offline   Reply With Quote
Old 04-02-2009, 03:41 PM   #14
Yes, but never heard of Red grease from Mobil-1 But for real cars you should know that they use Synthetic OIL unless you mean oil instead of grease.
I use Teflon Grease!!!!
Every time you rebuild a shock do you not install the parts back in after cleaning them I have worked with AE shocks many times, never had any problems with any of my installations. Never had any leaks whatsoever. But I bleed bubbles out on every installation. Are you sure your tightening it all the way? I've never had a problem with AE shocks on my RC10GT that I've had for 12 years, unless the new AE shocks are of less quality standards.
The technical name for the nut on the shock itself, effects the pre-load which in turn adjusts the ride height.
Old 04-02-2009, 03:56 PM   #15
Suspended
They have been making synthetic grease for as long as they have been making synthetic oil.
I know the "technical name" for them ~ but there's no reason to oil or grease them.
Team Associated TC5 RCknight Electric On-Road 13256 12-15-2017 05:13 PM
Team Associated TC4 Kenshin Electric On-Road 15368 12-15-2017 09:23 AM
CRC Battle Axe, GenXPro 10, 1/10th pan, Brushless, Lipo,4c, Road, Oval,TipsandTricks John Stranahan Electric On-Road 1776 03-01-2016 01:18 PM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 11189 03-12-2013 06:52 PM
New to RC, started with a TRAXXAS RUSTLER but not happy.. Galo Rookie Zone 31 04-07-2009 03:51 AM
Team Associated FT RC8/Jammin Big Bore Shocks Mike Elam R/C Items: For Sale/Trade 16 06-13-2008 07:53 PM
