E revo dual Battery hookup question (Help!)
Im running two 2s 5000mah batteries on a mamba max esc. Was told I need to run them in series. I got a skimatic but had some questions as far as the positives and negatives on the deans plugs.. Is this correct? I just want to make 110% sure so I dont smoke my esc or batteries...
http://i6.photobucket.com/albums/y21...Untitled-1.jpg |
You are correct. I would not use the female connector. those would be the wires comming from your ESC.
If you are using a regular mamba max, you will need a bec
Originally Posted by badassrevo
(Post 5433336)
