Old 02-12-2009, 01:36 PM   #1
Default need help with settings on my venom charger
I want to put my battery through some cycles of discharging and recharging, but i don't know what to set the Amps and Volts to. My battery is a 4600MAH NIMH, and i have the venom charger. In the discharging section you can set the A's any where from .1 to 1.0 or something like that, then you can set the V's to default or a specific number.
Alan HII is offline   Reply With Quote
Old 02-12-2009, 01:48 PM   #2
trickedyfz450's Avatar
I would charge them at 6 amps and discharge them at 10amps the volts is for however many cells you have (6cell =7.2 volts) You shouldn't really have to mess with the volts much though unless you are adding or taking away cells.
Bumps And Jumps Rc
trickedyfz450 is offline   Reply With Quote
Old 02-12-2009, 02:10 PM   #3
But im pretty sure i cant set it to 10 amps.
Old 02-12-2009, 07:15 PM   #4
I am not all that familiar with the venom settings but I would say discharge as high as you can if you can't do 10 amps.
Bumps And Jumps Rc
