Old 02-12-2009, 09:17 AM   #1
CDF
Default loose battery cable
i just bought a rustler xl-5 and i also bought 2 venom 3000mAh NiMh battery packs...and i just noticed that the positive is already startin to slide out the back of the connector....i'm a newbie to this stuff and wonder if there is a quick fix and if this will be bad to use or still good? it has the high current connector in case you need to know that....
thanks
chris
Traxxas STRC Slash VXL
Traxxas Nitro Rustler
CDF is offline   Reply With Quote
Old 02-12-2009, 10:46 AM   #2
replace the connector, something like a Deans wont come loose since the conductors are actually molded into the plugs.
demon510 is offline   Reply With Quote
Old 02-12-2009, 01:49 PM   #3
CDF
i'm guessin they are/have the traxxas high current connector?
Old 02-12-2009, 02:25 PM   #4
No, you would have to cut the wires and solder them onto their perspective positions on the new plug. The Deans connectors would actually replace the Traxxas connector, so you would have to do it on all of your battery packs and chargers.
Your local hobby shop could always solder on a new traxxas connector or a deans connector. I know my LHS does it for free if you buy a connector from them. Hell I will fix it for you if you live in the Dallas area, it is not a hard fix if you have a soldering iron. I only suggested you replace your connectors because deans connectors are solid and wont give you any issues unless you mess up on the soldering.
Old 02-13-2009, 08:44 AM   #5
CDF
thanks for the offer...but i live in greenville, ohio (50 miles NW of dayton)....so i don't think that would work but i might just have to check into those connectors...thanks for the input!
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
1/8th scale Motonica smac Nitro On-Road 1830 01-16-2012 10:34 PM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
Tracks in China renjie Track Locator Forum 564 05-08-2009 02:51 AM
Nomadio/Sensor clmbia45 Electric On-Road 30 03-07-2006 05:47 PM
